Question about Canonical Ltd. Ubuntu
Ubuntu Screen How do I set the screen resolution on Ubuntu?
  • 981 Answers
The same way you set it on any Linux.  If you don't like the gui setting controls in look/feel, feed in boot commandline options or go into /etc/x11/xorg.conf and throw in a few likeable resolutions and restart X.
   These answers are totally in the bundled notes and documentation, not to mention the Ubuntu wiki; why ask here if as if something is broken in a unique way?
Posted on Sep 10, 2008
I have a desktop PC with HP v72 monitor and a GeForce FX 5200 video card installed. I uninstalled Windows XP and installed Ubuntu Server 11.04. The problem is that after the initial boot screen my monitor...
why run server, , sure you actually want a server.. sure.
Linux, run the newest Ubuntu on new pc
or older on older pc, ive no idea at all what PC you have.
v72 old CRT , glass tube monitor a RELIC in today world.
why post OS questions lacking what HP computer you have of 1000s.
XP gone great idea, for sure....
OK F8 is Microsoft , for get them it not MS now, not at ALL.
in the Linux world its failing to find the correct minimum or
best resolution to match your old monitor
the monitor is year 2000.
the best resolution is 1024 x 768
you are using new linux, and it does not use that old old CRT
weak as a cat resolution,
you can use and older linux, or newer monitor
or change the resolution
using
if seen and done this 100s of time, endless,
btw your OLD CRT monitor does not use proper PnP plug and play
data comms.. its too old, why mess with CRTs in 2017?
walmart sells a $45 LCD , use that? and avoid darkages resolutions.
the way to do this is to run in command line mode
and change the config file, called, xorg.conf
https://techblissonline.com/ubuntu-804-set-default-resolution-1024-768-virtual-pc-2007/
there are other ways,
recompile the kernal to default to this reso? relic
or there is hot key at boot, read the manual on ubuntu
and change to lowest poor resolution
then run setups with a working desktop.
ask on a Ubuntu forum, it can vary by year, OS made and version
and what what desktop running of the many.
https://wiki.ubuntu.com/X/Config/Resolution#Resetting_an_out-of-range_resolution
keep in mind
your CRT is not supported now.
you must force it.
one more for V12, dropped the startup manager, wow....
best is to ask only for your version and choices at install time.
grub , KDE? what?
http://ubuntuguide.net/monitor-signal-out-of-range-problem-in-ubuntu-12-04-precise-fresh-installation
Jun 11, 2017 | HP V72 17" CRT Monitor
I am using ubuntu 10.04 linux operating system ,but it,s screen resolution is not good .is there any possibility to download and install any vga drivers to get better resolution
Go to System, on the top bar, then Preferences and select Monitors.
On the Monitor Preference screen there will be different resolution settings that you can choose.
If there are any resolution settings higher than 800X600 like 1024X768 etc. select it and apply.
If there is no other settings available go to System then Administration and select Additional driver.
When the Additional drivers screen appears check if it recommends a a driver to be downloaded.
If it does, download the driver and then you will be able to get higher screen resolutions.
If there is no additional driver to download it gets a bit tricky.
You will need to edit your /etc/X11/xorg.conf file.
The file will look someting like this:
Section "Monitor"
Identifier "Philips 190S"
ModeLine "1280x1024" 108.0 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
Option "PreferredMode" "1280x1024"
Option "DPMS"
HorizSync 30-82
VertRefresh 56-76
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Philips 190S"
Device "Default Device"
DefaultDepth 24
SubSection "Display"
Depth 8
Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Module"
Load "glx"
EndSection
Section "Device"
Identifier "Default Device"
Driver "nvidia"
Option "NoLogo" "True"
EndSection
It will be wise to make a backup of this file if you are going to edit it. (xorg.conf.old)
Inside the file you will see your screen and its resolution. (Preferred mode)
You need to change the resolution, save the file and restart your session.
If all went well your resolution will be set to what you specified, if your display freaks out replace the xorg.conf file with the xorg.conf.old file.
Hope one of these options solves your problem!
Regards
Nov 28, 2010 | Vga (CAT5-1000S/R) (EXTCAT51000)
My screen resolution is changed when i installed ubuntu 9.10. It is not detecting my monitor.
your systems graphic may be Nvdia graphic,try to start in recovery mode or command line and install nvdia drivers manually in command line.
Jan 12, 2010 | Canonical Ltd. Ubuntu
I have a Compaq FP 5314 that flashes on and off at about every four seconds. It works on XP and shows everything up to the OS coming on. That is all the bios type info, but then starts flashing as above....
The problem is that UBUNTU is setting the screen-resolution to some values that your monitor does not support, e.g., 1920-by-1080, or not setting it to 60Hz.
During boot-up, your monitor uses 800-by-600, so it "initially" works, both with UBUNTU and XP.
Windows "detects" the monitor, and selects "usable" settings.
Attach a new monitor to UBUNTU, and then set the video-resolution to 1024-by-768 and to 60 Hz -- your Compaq should support those settings.
Dec 26, 2009 | HP Compaq FP5315 15" LCD Monitor
Screen size
I think you will get an answer hre
http://ubuntuforums.org/
Oct 03, 2009 | Philips 150S (White) 15" LCD Monitor
Screen resolution too low.
You will need to compile the drivers. This is difficult but not impossible. Plenty of information on the Ubuntu Forums regarding this.
Aug 21, 2009 | Computers & Internet
Trying to run ubuntu
It sounds like Ubuntu chose a screen resolution that your monitor doesn't support. For the sake of sanity, I would a reboot and then try booting to Windows to ensure that what camone311 suggests happened isn't so -- I doubt it, as the install process is more involved than just 1 click - there are SEVERAL variables (time, date, username, passwords, how much of the hard drive to use, etc) that have to be set before anything is written to the hard drive.
If you're able to boot to Windows, then I would boot back to the CD and give it another go. At the menu where it says Try Ubuntu... there's an option to change the graphics modes - I would try safe graphics mode or VESA to see if that fixes the black screen problems that you were having.
Jan 05, 2009 | Computers & Internet
Ubuntu Screen Problem
try resolution change or refresh rate look in system files i know linux is hard the first time unbuntu forums .com helped me a lot a lot of questions answered there just trying to help with some sites i used without typing answers and don't want to confuse you
Sep 04, 2008 | Canonical Ltd. Ubuntu
Canonical Ltd. Ubuntu Logo
133 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
none
Dennis Gutowski
Dennis Gutowski
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
