Question about HP LaserJet 3015 All-In-One Printer
LaserJet 3015 There is a fine vertical line printed about 2 inches from the left side of all items received. Do you know how to stop that happenning? Many thanks J Taylor
I have a vertical line approx. 3" from right edge of paper. It only appears on copies made or faxes sent out. It does not appear on anything printed from the computer. If this is a cleaning issue, how do I get to the glass or whatever, to clean it?
Thanks,
Carol
Posted on Oct 09, 2008
The line was not a crack in the glass-as I thought it might be.
However, I cleaned the two sides of glass with piece of clean kitchen roll and it is clear now!
Thanks
J Taylor
Posted on Sep 11, 2008
Multifunction HPLASERJET 3015: when I start copying a document will always print a black vertical line on the right of the page
Advisable for users & tech guys: Lift document feeder unit clean "scan head" glass with glass cleaner, check..
Sep 24, 2011 | HP LaserJet 3015 All-In-One Printer
I have a HP Laserjet 3015 fax machine connected to a phone line but not a computer. When I send a fax or make a copy a dark vertical line appears on each page. Incoming faxes print with no line. I have...
The fax scanning unit/encoder is dirty.
The fax scanning unit is like a camera. It take a picture of the document.
The glass plate is dirty and you may purchase a FAX CLEANING SHEET.
Officedepot
http://www.officedepot.com/a/products/470251/Office-Depot-Laser-Printer-Cleaning-Sheets/
or similar product to clean out the dirty area.
The dark strip is cause by semi-dry wipe out correction ink.
Give your unit a good cleaning and let me know.
Jul 08, 2010 | HP LaserJet 3015 All-In-One Printer
White line to left of every page that is printed/copied. HP LaserJet 3015
you have to clean or replace your scan unit, call the technician
Apr 07, 2010 | HP LaserJet 3015 All-In-One Printer
HP 3015 laser printer with ghost image
A fuser image should only be about 1 1/2 inches away, 3 inches sounds like a drum problem.
Aug 03, 2009 | HP LaserJet 3015 All-In-One Printer
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Printing problem
the problem exclusive between the drum or the fusser unit
Apr 25, 2008 | HP LaserJet 2550L Printer
Scanning Problems
I need some more information are the lines horizontal or vertical? Does it print fine from the computer? Does this problem only happen when you scan an item in and then print it or copying an item then print it? Also when you get this output do you have some of the text and lines or just lines?
Jan 08, 2008 | HP LaserJet 3050 All-In-One Printer
Hp LaserJet 3015 Printer.
is it wavy? if so then it is either the toner cartridge or the fuser unit (heat section) I would go for the fuser unit as the hot roller that makes the toner stick to the paper is only a plastic film. Have you noticed any gray pieces of plastic coming out?
Hope this help you and you can get these machines repaired also please rate me
Cheers J
Dec 28, 2007 | HP LaserJet 3015 All-In-One Printer
HP LaserJet 3015 All-In-One Printer Logo
142 people viewed this question
Ben Johnson
