Question about Car Audio & Video
Kenwood KRC-656r Hello, I have KRC-656r and rear chanels are not working. Could you please find for me wich power IC is used as a rear channels output amplifier. because the text on the original IC-s is wanished. Thank you.
AN7190 2x20W stereo amplifier
Posted on Sep 11, 2008
Chanel lock
The Kenwood TK-3312e is a EU version of that handheld If you truly have that model# 3312e and not a TK-2312e.
Then you don't have VHF here the specs for the posted model# you gave.
Frequency Range: 400-470 MHz 5 Watt RF Output 128 Channels/128 Zones Built-In Voice Scrambler QT, DQT, DTMF and 5-Tone Signalling FleetSync Digital Signalling, PTT ID and SelCall MDC-1200 Signalling PC Programming
Jul 01, 2014 | Kenwood Tk-2312e / Tk-3312e vhf / Uhf...
Kenwood amp sound goes on one channel
You will need to check on the failed channel with reference from the working channel. If the model is having an IC check for the fusible resistors in the biasing circuit. If not your output IC could be faulty.
Open the set and check for any loose connections. make sure your speaker is fine and cross check for confirmation.If the speakers , the fuses are intact, then you will need to signal test to see if the premap is working or the output is at fault. So check this out. Good day
Jul 24, 2010 | Kenwood Audio Players & Recorders
I have a kenwood KRC-509S cassette and i forget the code ...??? so is there any way or any tips to open my 509S again... if u know the solution please send it to my email.
The code will only be available from your Main Dealer or by using a Radio Decoding Service who will read the working code inside your radio`s memory chip (EEPROM) using a laptop and special software
Jun 19, 2010 | Kenwood KRC-509S Cassette Player
I have a vintage Kenwood amplifier (two channel rear speakers, 4 channel front / satellite) with Dolby Surround. It is circa '98 or so. I just moved it and now the right channel of the rear speakers seems...
I can't provide specifics without the model number, but ingeneral, the amp section for the rear speaker could be defective or the output relay could be the problem. Without knowing the deisng, I can not say for sure. Typically, the units of that vintage, use ICs for the surround amps. Some use a single IC for both channels, some uise 1 per channel. If you can update this with the model number, I can get you more specifics and perhaps a repair cost estimate.
Thanks,
Dan
Nov 24, 2009 | Kenwood Audio Players & Recorders
Front right speaker got wet, started cutting out. at the same time the rear right speaker started cutting. switched the rear speakers to opposite channels and this caused the right to work and left to cut....
the speaker getting wet will short it out. Shorting the output on any amp will ruin it. there is a right and left chanel with 2 outputs. Right chanel is damaged.
Sep 30, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Does a Kenwood KRC 278 R have RCA inputs?
the rca are outputs.
get a fm modulator.they sound good and are so simple to use.
May 28, 2009 | Kenwood Car Audio & Video
I have a kenwood krc-3005 radio I do not have a wire diagram can you help
Yellow (+) Constant 12 Volts
Red (+) Switched 12 Volts
Black (~) Ground
Blue w/white stripe (+) Remote Out(used to turn
on the amplifiers)
Orange w/white stripe (+) Dimmer IN(used to dim
the display of the unit)
NOTE. if you dont want to hook up this wire it doesnt matter)
SPEAKERS OUTPUTS
White(+) Left Front
White w/black (~) Left Front
Gray (+) Right Front
Gray w/black (~) Right Front
Green (+) Left Rear
Green w/black(~) Left Rear
Purple (+) Right Rear
Purple w/black (~) Right Rear
Jan 04, 2009 | Kenwood KRC-207S
Kenwood KRC-2001
That's for a cd changer.
Jul 08, 2008 | Car Audio & Video
CASSETTE RECIEVER...(KENWOOD)KRC-585/M3
can you please find a cod for keenmood krc-585/m3
thank you
Sep 26, 2007 | Kenwood KRC-38MR Cassette Player
Car Audio & Video Logo
98 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
