Question about Canonical Ltd. Ubuntu
Ubuntu Monitor Inserted the Ubuntu live CD into my computer, and my monitor said "frequency out of range", why did I get this message?
  • 981 Answers
It's a monitor design quirk causing that.
You got the message because Ubuntu read the info your monitor fed back to your videocard and somehow understood it could run the monitor at a higher or lower frequency than the monitor can really work with; say, 120Hz rather than 70 or 55Hz refresh rates.
 If you don't even get the first logo menu, try hitting either down-arrow, then enter, or F4.  Those correspond to menu choices to boot in failsafe graphics mode or get the menu in such a mode.
Posted on Sep 10, 2008
Get rid of "Out Of Range" message on e218c1 monitor.
The device driving the monitor is exceeding the horizontal and vertical frequencies that the monitor can display .....thus the "out of range". The specs for this state that the Horizontal Freq. is 80Khz and the Vertical Rate is 75hz. If you are driving this monitor from a computer running Windows, reboot the PC and use the F8 key to put it in SAFE mode. This will cause the video driver to default to a rate that the monitor can handle. Then go into the screen resolution settings and reset them. The native resolution of the monitor is 1680x1050 at 60 Hz. Exceed that and you'll get the "out of range"
Sep 10, 2014 | Envision Peripherals 22"" envision e218c1...
In same games as Jewel Quest 3 the monitor give this message the single over rang
Signal OVER RANGE?
Monitor unable to cope with the frequency the computer is sending (for want of a better explaination.
Boot the computer to VGA mode and adjust the display settings, or boot to safe mode
Jan 04, 2011 | GNR 19M1 19" LCD Monitor
Frequency out of range 11khz/ 119khz message
The PC is sending out the resolution that is too high for the monitor to handle, you need to set the resolution of the PC to be the native resolution of the monitor and set the refesh rate to be at 60Hz.
Jan 12, 2010 | Envision H191W Monitor
I get a message, "Frequency out of range. Nothibng else. The menue and other buttons don't do anything. Nothing else shows. I swapped out the monitor and the new one works.
This problem arise when your computer AGP driver not adjust monitor frequency.you fix it restart your computer and run safe mode settings resolution area(must be choice less area)or select 1024X768 pixel monitor frequency 60Hz press apply set OK.restart your computer.Run again normal mode.May be fix your problem.
Dec 27, 2009 | Princeton Digital VL1916 19" LCD Monitor
Out of range message
This is caused by a resolution and/or refresh frequency setting in your computer's display properties that exceeds the values supported by the monitor.
Find out the optimum (native) resolution of your monitor (in case of AMV 17V5 it will be 1280x1024 pixels), and supported refresh frequency (usually 60Hz for LCD monitors), and set your display properties to these values.
Nov 23, 2009 | Amptron AMV 17V5 17" LCD Flat Panel...
Sonicview VG 2021 - Out of Range message
..hi..just select menu on the front panel of LCD the find the option Auto then click Auto..good luck..Thanks...^_^
May 11, 2009 | ViewSonic Graphic VG2021m LCD Monitor
Ps3 to gateway fdp1760 frequency out of range dvi to hdmi cable
what Frequency is the monitor set to run at ? u will get that mesg whan the monitor is receiving a signal that is greater than what it can handle say ur monitor can take 1024x768@60hz from ur PC and maybee ur PS3 is sending 720x720@100hz so ur monitor can handle the resolution but not the refresh rate that would be why u get that message
Mar 07, 2009 | Sony Playstation 3 (PS3) Console
White horizontal lines of static on monitor
Can you try reducing your monitor refresh rate to a lower frequency, or the lowest frequency.
Apr 10, 2008 | HP Pavilion F1703 17" LCD Monitor
Canonical Ltd. Ubuntu Logo
54 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
none
k24674
Jaipal Reddy
Jaipal Reddy
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
