Question about Concord Camera 3346z Digital Camera
Camera will not respond
File error appeared on screen,then when powered on hour glass appears on screen,and then no response at all from camera appears to be locked up .no working functions.
    Champion:
  • 277 Answers
Hi your memory card had retired buy a new 1 good luck
Posted on Apr 06, 2006
Will not go past initial start up arrow and hour glass on gateway screen f8 onstart up will not help
at start up, tap it constantly until the menu appears if it doesn't work try F12.
Dec 18, 2013 | Gateway MX3410
Tip
How to use System Recovery console (steps)
Starting a Recovery
Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears.
You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP .
Back to top
Recovery is taking too long
If your computer stops responding after using the recovery program, do the following:
NOTE:If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
1 Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
2 Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
3 If you are using recovery discs, be aware of the following items:
4 If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
5 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
6 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
7 If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
___________________________________________________________________________________________________________________
2 If you are using recovery discs, be aware of the following items:
3 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
4 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
5 Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
on Oct 13, 2011 | HP Computers & Internet
My screen appears but the mouse cannot open files and displays hour glass on taskbar hour
Clarification Questions:
1. Have you downloaded something before it happens?
2. What was the last thing you did with your computer before it happens?
Feb 28, 2013 | ASUS Eee PC 900HA Notebook
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
Jan 13, 2011 | Compaq Presario 5000 PC Desktop
Will not open. hour glass appears and will not go away
cannot get into my email the hour glass comes up and it says not responding. could you help me solve this problem
Dec 17, 2009 | Yahoo Mail
79.03 error
you will need to contact hp support (yes in india)
Ask them to send you a .plt file, this only applies if you are able to ftp to your printer whilst in the diagnostic mode.
If ftp is not an option request an .exe file called PRNter.exe, with this you can sent the .plt file to printer through usb.
If non of these options will work you need to request a new formatter, and like me they will charge you for the part, as hp will not take responsibility for a bad firmware update. Even when i have a screen capture vid showing being unable to download anything of the hp server at the time of a botched firmware update rendering the 3100 brocken and un fixable without a new formatter.
A two week fiasco still pending for me
hope this helps  if need any more help i am at asylum119 at hotmail dot com
May 02, 2009 | HP DesignJet Z2100 InkJet Photo Printer
Can't get started
Could it be that the SD card is not fast enough? I think that SD 40x or SDHC class 6 is needed from my experience (I am not sure what it says in the manual). What speed/class is the card you are using? I get these sort of problems intermittently on my HD2 (the predcessor to the HD1000) when I use a slower card.
Dec 30, 2008 | Sanyo Xacti VPC-HD1000 Flash Media...
Displays 'App Error 523' Reset on blank white screen
The software has become corrupt on your handset. install Desktop Manager on your PC and download the latest handset software from here:
http://na.blackberry.com/eng/support/downloads/download_sites.jsp
Good luck.
Gadget
Dec 04, 2008 | RIM BlackBerry Pearl 8100
Power Up Hour Glass appears an stays on for 3 hours
This should help. When the hourglass symbol stays on, press and hold down the start button for at least 15 seconds. The screen should clear and then you can navigate back to the correct opening screen and select music, videos, photos etc. as you require.
Nov 26, 2008 | Archos 405 Digital Media Player
Error message
Your camera probably doesn't have a problem. Mount a lens on it and turn the aperture to the smallest opening = F/22 or F/32 then try it.
Nov 05, 2006 | Nikon F65 35mm SLR Camera
Concord Camera 3346z Digital Camera Logo
67 people viewed this question
Top Concord Cameras Experts
Michael Galve
Michael Galve
Are you a Concord Camera Expert? Answer questions, earn points and help others
