Back to:
Tags:
Sharp 25R-S100 25
Speaker squeal
posted by nkey on Apr 01, 2006
I have an amazingly LOUD squeal coming from the left speaker only. When I turn the volume down completely the squeal is unchanged. How can I fix this? If this cannot be fixed, can I just go in and disconnect this speaker? I could then change the setting to mono or just run the sound through my stereo. Currently running it to the stereo does not turn off the sound at the TV, I tried that to just work around the problem.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 02, 2006
FixYa! (100)
techman
Rank:Guru Guru
Rating: 87%, 6806 votes
ok if you dont wanna replace the audio output ic in this set you can simply disconnect the speakers in the set but tape them up so they wont short out against anything and then you can run the sound into your sound system of choice if it has an audio outputjack
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on speaker squeal:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
Sharp 25R-S100 25" TV
no power only pilot light will lights up...but theres no...
I have aquired a sharp 25' tv, I recently got a sharp vcr...
queria saber como consegir o codigo para entrar em modo de...
i lost my manuel from sharp54dt-25s i can program nothing...
how to find code for sharp tv
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
