Back to:
Tags:
Kenmore 24982 Top Load Washer
No water pressure
posted by helpme on Apr 01, 2006
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 02, 2006
Not Rated (0)
MadhaT
Rank:Master Master
Rating: 79%, 75 votes
Hi
There could be couple of causes to this problem so you need to be more specific, still here are a few things for you to check.
Check the inlet valve and the protective screen that?s inside ? it?s probably clogged, although you can clean the screen its better to replace the valve.
Check your water pump if it working properly.
Remember if you don?t have any(!!) plumbing experience don?t try it yourself and call someone.
Good luck
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on no water pressure:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Washing Machines
el suiche de la lavadora se me dano el de la puerta de...
Washing Machines
mould and mildew forming around the rubber seal of the LG...
Washing Machines
Bosch Next 300 Whats the trick with stretching the metal...
Washing Machines
i have a bosch washer dryer wvti 2840, have put some...
Why do clothes get caught in the agitator?and how can I...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
