Question about Canon PIXMA IP5200 InkJet Photo Printer
A big PGBK ink cartridge problem
After replacing a new cartridge won't print. nozzle clearing won't help. what can I do?
  • James Mac
    James Mac May 11, 2010
    Did you remove the small plastic film covering the bottom of the cartridge?  Let me look at your manual about priming.
    James Mac
    Scholar:
  • 71 Answers
Call - 1-800-828-4040
Verify they are installed correctly.
Remove the print head or ink tanks properly following the procedure below.
1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.
Note: When the top cover is opened more than ten minutes, the print head moves to the right side. If this occurs, close the top cover, and open it again.
2. Open the paper output tray and pull down the inner cover.
3. Remove the ink tanks by pressing the tab of each tank.
Note: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. When replacing multiple ink tanks, make sure to replace one by one.
a big PGBK ink cartridge problem - ip4200_ink_remove.gif4. When removing the print head, raise the print head lock lever first.
raisephlocklever.gif To reinstall the Print Head and Ink Tanks
1. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.
2. Insert ink tanks into the print head.
Press the mark 'PUSH' on the ink tank firma big PGBK ink cartridge problem - ip4200_ink_install.gifick.
3. Ensure that all the ink tanka big PGBK ink cartridge problem - ip5200r_ink_tank_seat.jpgand the ink tank lamps light red.
<1> The ink tanks are installed properly.
<2> The ink tanks are not installed properly.
Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes.
On: The printer is ready to print.
Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
Off: An error has occurred and the printer is not ready to print.
4. Put back the inner cover and close the top cover.
Note: When starting printing next time, the print head cleaning launches automatically.
During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
James Mac
Posted on Sep 10, 2008
Cannon Pixma MP780 won't print. Just replaced black ink cartridge, do I have to replace all of them for it to print
Not normally but the black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 08, 2013 | Canon PIXMA MP780 All-In-One InkJet...
Canon mx860 printer not using ink from PGBK 220
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
My PGBK ink cartridge is not printing. I just replaced it. Everything else is working fine. I have done several cleaning jobs on it and the test prints that I print don't even show PGBK or the black...
the PGBK ink cartridge might not be getting a good connection you might have to remove it and check the connections or clean the connection bars
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Oct 21, 2011 | Canon Pixma iP4500 InkJet Printer
I have installed a new ink cartridge and the z645 printer. It sounds and acts like it is printing, but the page is blank. After I first installed the new cartridge, I printed a test page, but only about 2...
Doing the "clean printhead/cartridge nozzles" multiple times would have cleared clogged nozzles. You can also try to manually wipe the cartridge nozzles with a slightly moistened soft cloth. If that still won't help, try to replace your cartridge with a different known working cartridge to determine if your other cartridge is faulty.
May 08, 2011 | Lexmark Z645 InkJet Photo Printer
I am snow bird; printer turned off for 6 months. I shut down properly. Now when doing print nozzel check the top PGBK pattern whole center portion is missing. I have cleande, deep cleaned twice and wiped...
It's manually unclogging.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0062.
Nov 17, 2009 | Canon PIXMA MP960 Printer
Canon PIXMA MP500 New Black ink cartridge produces no ink
If you don't use it very often the black could have dried in the printhead, and you will need a new one. Another possibility is that the purge unit is not cleaning and priming the printhead properly. I have seen several defective purge units. For 1 year it can be replaced under warranty, after that it is a $90.00 repair job in the shop.
Jun 25, 2009 | Canon Pixma MP500 All-In-One InkJet...
Not printing black ink after replacing cartridge
Unfortunately I have no idea which compatible cartridge you're using so it's difficult to provide a definite solution. However a few things to consider:
1. The cartridge needs to have a clear vent hole so if you haven't removed tape or a plug from a hole that was indicated in the instructions, you need to do this.
2. Try removing the cartridge and then touching the exit port on the cartridge with a Q-tip (cotton bud) to see if the ink flows to the cotton. If it doesn't you need to replace the cartridge.
3. Check the cartridge is sitting properly in the printhead.. The interface between the printhead, rubber grommet and the cartridge exit port is very important and the cartridge needs to sit in this properly.
My guess is that the compatible cartridge is not up to the job and you need to consider getting an OEM (Canon original) instead.
You may want to think about finding a refill kit and using the Durschtich (German) method of refilling using bulk ink and a chip resetter instead of compatibles.... Nifty-stuff forums have a LOT of information on this subject so it's well worth a look.
Hope that helps.
Martin
May 27, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Pgbk cartrige
Your printer works with the PGI-5BK cartridges, that are in fact just ink-tanks, the printhead being apart of the tanks, so if the cartridges are not empty, it cannot be because of them. It doesnt matter if you replace the cartridge, the problem is in the printhead.
If the problem occured just a while ago, you should consider that NOT PRINTING a long time (30 days) with a printer can lead to ink drying out in the printhead, clogging the nozzles. OK, now it comes: If you have some tehnical skills, you can remove the cartridge and desassembly the printhead (where the cartridge are in) and do the following:
Put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the printhead with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridges back on the printhead (without installing it in the printer), rap it in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the printhead on some sheets of tissue.
Get the cartridges again out of the printhead, install it in the printer, then install the cartridges again and run a few cleaning processes from the printers maintenance software.
It should work. If you dont have the tehnicall skills needed, Canon gotcha, or you can visit a local specialist to make all this for you, they usualy have better equipmens, as ultrasonic cleaners and special solvents that makes all this easyer.
Rate the solution if it helped you!
Thx.
Feb 03, 2008 | Canon Pixma MP800 All-In-One InkJet...
Canon PIXMA IP5200 InkJet Photo Printer Logo
355 people viewed this question
old marine
old marine
Corne Viljoen
