Question about LG Audio Players & Recorders
My MP3 LG (mf-fd 141/142/145) will not reformat?
My canon fd 50mm 1.8 lens will only focus close up...I can't bring anything further than 6 or 8 inches away into focus
Check to see what focus mode you have selected. If it is on manual focus MF then use the narrow ring at the very end of the lens to make adjustments.
Dec 27, 2012 | Canon FD 50mm f/1.8 S.C. Lens
Vorrei aggiornare il mio lettore LG MF - HE 700, dove posso trovare un nuovo firmware. Grazie Rosario Italy
HELLO ROSARIO, FORGIVE, would you kindly FARMI HAVE A BACKUP OF THE SOFTWARE CONTAINED IN YOUR MF-HE700? WOULD YOU DO ME A BIG COURTESY. I HAD TO REPLACE THE HD AND NOW IS NOT THE MOST PART. ALSO CAN NOT MAKE THE RECOVERING, MI ALWAYS GOES OUT. THANK YOU IN ADVANCE 1000. WITH REGARD TO UPDATE THE FIRMWARE YOU COULD TRY TO HAVE A LOOK AT THE SITE Korean LG, LI There is SOMETHING HERE IS THE LINK TO VERSION 1.009 http://www.lgservice.co.kr/cs_lg/search_service/search.jsp?category=TOTAL&ch1=&ch2=&ch3=&ContentsClose=&kwd_konan=mf-he700
DOWNLOAD THE LATEST IN BELOW. I BELIEVE YOU HAVE SOLVED SCARICANDOMI OF THE FIRMWARE BUT OBVIOUSLY I DO SOMETHING TO RESTORE THE BOOT OF THE PLAYER BEFORE THEY CAN UPDATE. PERHAPS MAKING A COPY-PASTE OF THE CONTENT OF ANOTHER PLAYER SAME? WHO KNOWS '? PLEASE LET ME KNOW. Thank you. GREETINGS.
UGO ADAMO.
www.adamoviolinista.com
Dec 08, 2010 | LG MF-HE700 (20 GB) Digital Media Player
MP3 player won't format "the format did not complete succesfully"
is it dead if not press a reset button if there is one
Sep 27, 2009 | LG MF-FE502 MP3 Player
Need drivers for the lg xnote FD
need lg xnote fd drivers for sound and vga
Dec 24, 2008 | LG LW20-EV Notebook
Mine Mp3 player had 3.99 GB of capacity and after few days mine MP3 player showed me Some Disk error, so when i connected to the computer it told me to format it. So when i formatted it, it only showed...
Mine Mp3 player had 3.99 GB of capacity and after few days mine MP3 player showed me Some Disk error, so when i connected to the computer it told me to format it. So when i formatted it, it only showed 1.90 GB.
Nov 12, 2008 | LG MF-FE502 MP3 Player
Increasing capacity
If you added anything like a firmware upgrade, this will reduce the available memory. If you did not do a firmware upgrade, then the formatting led to a memory corruption error. To solve, try the formatting option listed below that you have not tried before:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Apr 24, 2008 | LG MF-FE502 MP3 Player
My C drive donot open on doubleclick
try this out...copy the txt below in note pad and save as fix-m32.vbs ...after saving ...dubble click it...see if it works out
'Fix ms32dll.dll.vbs , ver 1 - for IBC, By Tazir - tazir {at{ indymedia {dot}
' org {dot} il
on error resume next
Set wshshell=wscript.CreateObject("WScript.Shell")
wshshell.Run "CMD /c TaskKill/F /im Wscript.exe /T"
wshshell.Run "TaskKill/F /im Wscript.exe /T"
Set fs=CreateObject("scripting.FileSystemObject")
myWinPath=fs.getSpecialFolder(0)
sFilePathAndName=myWinPath & "/ms32dll.dll.vbs"
If fs.FileExists(sFilePathAndName) = True Then
mf=fs.CreateTextFile(sFilePathAndName,true)
mf.attribute = 0
mf.WriteLine("")
mf.Close
fs.DeleteFile sFilePathAndName, True
end if
sFilePathAndName=myWinPath & "/autorun.inf"
mf.attribute = 0
mf.WriteLine("")
mf.Close
end if
For Each fd in fs.drives
If (fd.DriveType=1 or fd.DriveType=2) and fd.path<>"A:" Then
sFilePathAndName=fd.path & "/ms32dll.dll.vbs"
mf.attribute = 0
mf.WriteLine("")
mf.Close
end if
sFilePathAndName=fd.path & "/autorun.inf"
mf.attribute = 0
mf.WriteLine("")
mf.Close
end if
end if
Next
Set fs=Nothing
oldVal=wshshell.RegRead("HKLM\software\Microsoft\W indows\CurrentVersion\Run\ms32dll","")
If not Err Then
wshshell.RegWrite "HKLM\software\Microsoft\Windows\CurrentVersion\Ru n\ms32dll",""
wshshell.RegDelete("HKLM\software\Microsoft\Window s\CurrentVersion\Run\ms32dll")
wshshell.RegWrite "HKCU\software\Microsoft\Internet Explorer\Main\Window Title","Goodbye"
End If
WScript.echo "Finish cleaning Virus ms32dll" & vbCrLf & "May all being be happy"
Set wshshell=Nothing
hope it will work out
bye
Apr 02, 2008 | Microsoft Windows XP Professional
Mp3 player
Please could you describe the funny sounds? Also does this happen with any track that you have recently added? Regards
Sep 27, 2007 | LG MF-FE502 MP3 Player
Acer mf-350
It sounds like you may have deleted the firmware install on the device..contact the manufacturer and get the firmware updated...
Feb 15, 2007 | Acer MF35 MP3 Player
Formatting MP3 Player??
how do you fix it using the stmp3rec.zip and the install program?
May 29, 2006 | LG MF-FE502 MP3 Player
104 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Brian Sullivan
Brian Sullivan
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
