Question about Hitachi Audio Players & Recorders
My new hitachi dmp200n is not charging when attatched to pc usb port Pc recognises it and installs drivers for it. Same thing happens in xp and vista
Hello i just have 3 questions pls answer i have an Hitachi mp3 player model : DMP200N 2gb and i format it but now it doesent work i think i erased his driver could u please tell me what to do now?? plz waiting
Posted on Jun 16, 2010
I have 500GB transcend Portabale hard drive but not working,need installation driver or some thing other ?
External hard drives connected to the USB port do not require any additional drivers for WIN XP, Vista or Win 7. If it is not being recognised at all then the USB converter inside the box is faulty. If the PC recognises the USB converter but not the hard drive then the hard drive may be faulty.
Feb 20, 2011 | Computers & Internet
Cannot be recognised on my USB ports
The CD supplied does not have drivers on it. This is a flash player so your PC should recognise it automaticaly.
If this is not happening, please try installing an MTP Porting Kit via the microsoft.com website.
Jul 14, 2009 | Samsung YP-S3JAB Digital Media Player
Sony Vaio USB ports not recognised by XP
It is common problem on most of the PC USB ports does not recognise external hardware.It is mainly due to lack power supplied by the USB Ports..You can try with Old Pentium4 maschines.IT Reads well..
Another thing dont use extension ports to plug external HDD..always use backside on board ports.\
IF it helps rate me
Jun 25, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
Tallygenicom 8008 not recognised in xp
I do not think there was a driver version 1.5 for the 8008 I believe only one version of driver was released for the 8008 for XP this was version 1.00
I think your search for later driver will be fruitless.TallyGenicom went Chapter 11 and are no more, I think thwy were taken over by dascom (www.dascom.com) who now sell Tally Dot Matrix printers.
I think your best option would be to check how the pritner is connected.
If connected via USB ensure the printer is correctly plugged in, make sure you have the USB cable connected to the USB port on the printer NOT the network port (it happens!!)
Plug the printer into a different USB port on the PC in case there is problem with the particular port.
Try a test page from the printer driver once you have installed it, see what errors you get.
If the printer is networked, ensure you can PING the IP Address, in the printer driver ADD A STANDARD TCP/IP port to print to the printers IP Address.
Post any errors or specific problems you see, how the pritner is connected we may be able to help some more.
May 04, 2009 | TallyGenicom 8008 Laser Printer
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Regards,
Mar 26, 2009 | Canon EOS 450D Digital Camera
Ibm think centre a 30
Windows XP has Drivers within the operating system to Install and setup USB Ports.
Here Are your options to Provide A Fix.
1: )The USB Port May Be Disconnected From The motherboard.
2:) The Device you are trying to Connect ( Pen-Drive ) May be faulty And Not Recognised By The Computer.
3:) The USB Cable Or Socket May Be Faulty.
Solution:- Try Connecting the Device To An Alternative ( different ) USB Socket On The PC.
Solution:- Try Connecting a Different Device to the USB Port. i.e MP3 player Or Digital Camera et,c.
Solution:- Check that the USB Header Cables ( from Motherboard To USB Ports ) Are connected Or incorrectly Connected.
Mike @ Compurepair.
*****Common Sense Comes As A Built In Feature*******
Feb 28, 2008 | Computers & Internet
USB problem
i think u must upgrade the USB driver on ur pc go to this link and download the driver and save it in desktop and double click on it and install it
http://usb-1394-firewire.free-driver-download.com/SIIG/31991/SIIG-USB-2.0-Controller-Driver-v0.216-Windows-98SE-ME-2000-XP.html
rate me solved if its help thx
Oct 30, 2007 | 2wire 1000-200004-000 Network Adapter
Not working
Has it worked since you received it? Can you hear/feel the drive starting or getting any power? Are any of the pins bent where the drive attatches to the case? Sounds like a power issue on the enclosure if your sure the drive is good. Try a different USB port/cable. Does the USB port work for other devices i.e.printer? Sounds like a returner. Let me know what happens. Good Luck, Tim
Mar 07, 2007 | Thermaltake A2397 Silver River R 2.5in...
My XP Media Center PC does not recognise the scanner
Your USB ports on your computer may be bad. Do other devices work if you plus them into the same USB port? You can try plugging the scanner into another PC with USB ports. If it works in the other PC, then that points to the original PC's USB ports. You can try buying an add-on USB port or using other USB ports on the PC. If it still does not work, then there may be a problem with the USB port on the scanner, and the scanner itself may need to be serviced.
Oct 16, 2006 | Symbol CS1504 Handheld Barcode Scanner
562 people viewed this question
Top Hitachi Audio Players & Recorders Experts
Man Ana
Man Ana
Level 1 Expert
 Grubhead
Grubhead
Are you a Hitachi Audio Player and Recorder Expert? Answer questions, earn points and help others
