Question about Canon CanoScan DR3020 Path-Through Scanner
Vista & Canon DR-3020
Is there a way to get the Canon working with MS Vista ?
It would be a life saver !
  • 490 Answers
As per CAnon Europe site, it looks only version 3 of CapturePerfect works in Vist environment. What version do you use?
http://software.canon-europe.com/products/0000666.asp
There is no mention about ISIS/TWAIN Drivers. In case you can load the drivers, you can try Microsoft Imaging to scan instead of CapturePerfect.
S. Mohan
Posted on Jun 05, 2009
Have Canon DR-3020 scanner. Installed, everything OK per Device Manager. ScanGear recognizes scanner and scans but Capture Perfect does neither. Any ideas?
I have worked on Canon scanners for many years and I am very familiar with the scanner you have now. That model of scanner will not work like a convential scanner do to its age and compatibilty with todays software. I have found a website that will allow you to download capture perfect to use on your scanner. If you continue to have problems you might want to email Canon directly to ask for a link that will be more specific to your scanner. Just remember when that scanner came out Windows 95 was state of the art for software. Since that time Microsoft has gone through several upgrades to windows. Here is the link and if you need any thing else let me know. I am very good with your model of scanner. I hope this helps you out.
http://www.driversquad.com/driver.php?option=o&prodid=60&cust=canon+scanner+software_AD_www.google.com_&channel=&subid=201_US*DR_o&roia=!iicYvq1BAAKLOkMAAAYOVQAAZT5CAABnCA-A
Mar 18, 2011 | Canon DR 3020 Path-Through Scanner
Hi got the following error message ... "ScanFile
I have many years repairing canon scanners so here is my suggestion to you.
First does the scanner power up? If so that's eliminates a internal power supply problem.
Second did anyone change the dip-switch settings on the back of the scanner? Ill assume no on that one.
Third when you first boot up your computer do you see a screen when the computer is in boot up mode that says Adaptec SCSI and then a number? If not here is a couple things to check. First I would check the SCSI cable is good. No bent pins in the connector and no exposed wires coming out of the connector. If you can try swapping a good known working cable with the problem scanner. Second try re seating the SCSI card if that doesn't work do you have another card that you know works that you can swap into the problem computer. After swapping the cable first test to see if the scanner scans, then if you replace the card again retest to see if the scanner scans.
Lastly and I have seen this happen, the drivers may get corrupted if new software is installed that relates to scanning. You may want to google DR 3020 drivers that should pull up Canon's web site and reinstall the drivers. Once you install the latest drivers then reboot the computer and test it to see if it now scans.
Im sure one of my suggestions should correct your problem. I hope this helps you out.
Need step by step instructions on how to download driver for Canon DR-1210c scanner for Vista.
http://www.usa.canon.com/cusa/support/office/imageformula_scanners/imageformula_dr_1210c/imageformula_dr_1210c_universal_color_scanner?selectedName=DriversAndSoftware
Hi, heres the link.
Thanks
Adam
please leave me some feedback
Feb 18, 2011 | Canon DR-1210C Scanner
May canon np 3020 ka machine liya hu. jab photocopy kiya jata hai to isme ek taraf kala aata hai. ye kis problam se aata hai
may canon np 3020 ka machine liya hu. jab photocopy kiya jata hai to isme ek taraf kala aata hai. ye kis problam se aata hai
Jul 24, 2010 | Canon Office Equipment & Supplies
I have a canon xerox machine model 3020 copy is not comming,blank white paper is comming
Canon 3020 is a scanner, not a copier. It can scan a document & store. If you print the image, you will get a 'photocopy'.
S. Mohan
Sep 18, 2009 | Canon DR 3020 Path-Through Scanner
Canon DR-3020 Scanner with Windows XP Pro
Download Dr 3020 drivers for XP from http://software.canon-europe.com/products/0000666.asp
Try connecting the scanner to a diff computer and check if it is okay. Also pls ensure SCSI termination is okay.
S. Mohan
Jul 09, 2009 | Canon DR 3020 Path-Through Scanner
Screensaver
Vista uses a different technology for screen savers than in the past. The screensavers and backgrounds are active. Older screensaver software (I inferred from your post that you had a favorite that both of you used and not one from MS) will probably not work here.
Jun 19, 2008 | Microsoft Windows Vista Ultimate Edition
Canon CanoScan DR3020 Path-Through Scanner Logo
221 people viewed this question
old marine
old marine
