Question about Hoover Vacuums
Brushes will not rotate.Square hole that brush fits in will not turn.
Pull out the 2 pieces on each end (don't be afraid...use a plyer it will eventually come out) - clean it with WD40 (you'll probably find hair wrapped around end pins) .... Spray again w/WD40 or a lubricating grease and put the ends back in (I used a hammer, again don't be afraid - it's metal and I've done it seveal times).
Posted on Sep 10, 2008
I have the f7425-900 steam cleaner and I don't see "2 pieces on each end". Two pieces of what on each end of what???
Posted on Feb 14, 2009
Brushes aren't turning. switch is on
Remember that the brushes turn best when the handle is tipped back. If this does not work, remove the brush assembly and insert a flat screwdriver into the square hole that the pin on the brush usually fits into. Try to turn the fitting. If it won't turn, the air driven turbine has seized up and will require replacement.
Jul 26, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Were can i find the belt on a hoover steamvac spinscrub the wheels quit spinning on it
There is no belt on the Hoover SpinScrub. The brushes are turned by an air driven turbine. To test the turbine, insert a flat screwdriver into the square hole that the pin on the brush assembly normally fits into, and see if the fitting turns. If it doesn't turn, the turbine has seized up and will need to be replaced.
Jun 20, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The brushes on my hoover f7411-900 carpet cleaner will not turn. any ideas? thanks, Hank
The most common reason for this is that the air driven turbine that turns the brush has seized up. To test it, remove the brush and insert a flat screwdriver into the square hole that the pin on the brush normally fits into. If you can't turn the fitting with the hole in it, the turbine assembly will need to be replaced. ( part # 91001019 ) - msrp $19.99. Be sure the square pin has not broken off from the brush assembly, as this is another possibility.
Apr 29, 2011 | Hoover Vacuums
How to disassemble the hoover steam vac2. the hole that the brushes snap into does not rotate so the brushes are not rotating
The hole the brush shaft goes into is the turbine that turns it. If it will not turn it is seized and should be replaced.
Feb 03, 2011 | Hoover F7425-900 SteamVac V2 Widepath...
Scrub brushes not rotating
Hi There,
You'll need to first diagnosis why these brushes are not spinning. When the SpinScrub brushes on a Hoover SteamVac don't spin, this can be 1 of 3 different things.
In order to diagnosis which one of the problems is causing your problem, here's what you'll need to do.
Step 1. The first and easiest thing you should check is to make sure that that the brush speeed selector knob on the top of the machine is turned on, and is not in the off position. This may sound obvious, but I've had several cutsomers that have come in with this exact problem, only for the brushes to be turned off. Also make sure that the SteamVac's handle is reclined, and not in the upright position. There's a switch inside that shuts the brushes off when the SteamVac is moved into the upright position. If the brushes still are not spinning, move on to step 2.
Step 2. You'll need to remove the SpinScrub brushes from the SteamVac. Turn the machine upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed (my left hand was holding the camera, lol), but the tabs on the left hand side are in the exact same location:
Step 3. Once the brushes have been removed, plug the machine in, make sure that the handle is reclined. Look in the SteamVac where the brushes used to be. You should see a hole that is square shaped where the brushes go into.
Turn the machine on, and look to see if this square shaped hole is spinning. If the hole is spinning, this indicates that either the brush block itself is bad, or there maybe something clogged (such as pet hair) in the brushes that's preventing them from spinning. If the square hole is not spinning, this indicates that your internal turbine brush gear has gone bad. Here's a link to a repair that I've written on how to replace the internal brush turbine gear if the square shaped, female receptacle hole is not spinning.
If the square shaped hole is spinning, here's what you may do to see if the brush block is just jammed up with debris, or if the brush block itself is bad and needs to be replaced:
Step 1. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem.
you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken. If the pole has broken, you will simply need to replace the brush block.
It can really only be one of these three things that are causing your brushes not turn. Here are links to all of the products that possibly need to purchased (if the brushes weren't just clogged) on our website for the model that you listed this repair under, the Hoover F7425-900.
- Hoover Brush Turbine Gear Assembly Part 43191009
- Hoover Brush Block SpinScrub 6 Brushes For F7425-900, Part #
I hope that this helped you figure out the problem. If you have any follow up questions, please use the Clarification Request form here on Fixya and I'll be more then happy to follow up with you and help you out. If you found this helpful, may you kindly please rate my repair helpful by clicking the thumbs up icons in the top right hand corner of the repair? This is really what keeps Fixya repair experts coming back to give free repair advice, and helps Fixya users continue to get the free replies without having to pay for answers. It's greatly appreciated.
Chris J.
Apr 13, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
I have a Hoover SteamVac SpinScrub. The brushes
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover stean vac dual with 5 brushes
I think this is the same unit I have, I might have a couple of solutions. No, there is not a belt that turns the brushes and there is not a fuse.
First of all, make sure the brushes have been clicked into the machine properly. The entire plastic housing unit for the brushes can be removed by pulling on the casing gently. It should pop out. Make sure the pegs and clips line up with the holes in the machine when reattaching the brushes. You should hear it click when they are on properly.
If the brushes are attached properly and they still won't spin here is another possible solution. This happened to mine.
The plastic pegs on the housing unit for the brushes might have been stripped out. The pegs are supposed to be squared tip to click into the square hole of the machine. If the pegs aren't the same shape as the hole, the machine can't grab them to spin the brushes.
The tallest peg on mine somehow got stripped to a rounded shape. I tried wrapping tape, plastic, etc around the peg to make it fit in the hole snug, but it only worked for a few seconds and broke again. I am going to have to replace the brush set. You can order parts from Hoover but I haven't priced them yet.
I hope this helps you.
Aug 30, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Brushes wont turn
Remove the brush block, turn the unit on its side and watch the square hole to see if it rotates. If not, then the turbine(#23) isn't working, if it is, then is the shaft on top of the brush block broke off, if it is, replace the brush block.
Jul 01, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
F6212-900 / F6215-900 SteamVac Agility
There is no belt, sounds like the turbine is bad and will have to replaced.
Nov 27, 2006 | Hoover F6212-900 / F6215-900 SteamVac...
Vacuums Logo
114 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
