Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
SOURCE: Whirlpool WTW58ESVW0 When set to wash,
Hi, Thank you for contacting
fixya.com. The
part that is causing the problem is the sensing switch. http://www.appliancepartspros.com/partpic/Z3BqLjNfbXNfNDg1MjkyMDFXL0xQVy9zb3RvaHB0cmFwLw%3d=.jpg Here
this link to order the part:- http://www.appliancepartspros.com/part_details.aspx?part_id=4501024 However
if there is insufficient water the motor will be stressed, and eventually
damaged. Other
problem could be a bad timer; pressure switch or the water level switch and any
short in the wiring harness.Please check this out to troubleshoot your problem.
Take a multimeter to test the components.
Please
get back to us if you have further query else please accept the suggestion.
SOURCE: My Whirlpool wtw58esvw0 washer will
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
