Question about Sony Hi8 CCD-TRV138 Camcorder
Reset button Please, where is the reset button located? I have an old CCD-TR82 Handycam, it records fine but couldn't play(read) the video in its own machine. I thought to do a reset, what if would work? Guess won't hurt to try... Thanks very much!
  • 19 Answers
SOURCE: Sony Handycam Model CCD-V801 does NOt Play
Hai, Check with previous recorded tape, If it is not playing. Clean video head with head cleaning cassatte. Before that please check is it going to VTR mode & also is it takes play indication. Then check with pre-recorded cassatte. thank you best of luck udupi
Posted on Mar 14, 2007
philipp
  • 217 Answers
SOURCE: drivers for ccd-trv608 HI-8
http://esupport.sony.com/US/perl/model-swu.pl?mdl=CCDTRV608&LOC=3
Posted on Sep 28, 2007
ctf1800
  • 4402 Answers
SOURCE: Sony Handycam Vision ccd-trv308
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Jan 22, 2008
welcomejee
  • 10594 Answers
SOURCE: Handycam says C:31:22
error 31:22 means camera mechanism has error in take-up reel section and micro processor isn't receiving reel signal so it shuts down playback/ record function immediately. look into take-up reel section of mechanism.
Posted on Sep 12, 2008
SOURCE: Sony Handycam Video Hi8 - TRV138- cassette - will not play -please reinsert
Hello Everyone!
My Handy Cam CCD TRV-138 was have a malfunction error by stopping and beeping and telling me to reinsert cassette.
HERE IS HOW YOU GET IT TO WORK.....
Let me first tell you that you need to call the Sony Service Hotline at 1-800-488-7669.
They will have their service tech help you to reset the camera, STEP by STEP and it will work fine after that.
You have to do several things in the right sequence in order for the reset to work. You can't just press the reset button and make it reset.
It doesn't cost anything to have Sony help you over the phone. They are all too happy to make sure that you are satisfied with their product and want to help you.
Mine was out of Warranty by 4 years and they still helped me without charging me.
I followed their steps and it worked. She had me first remove the cassette tape from the camera, turn off camera, remove the battery, then she had me turn the camera back on, then she had me take a pen or pencil and push the reset button, that is below the volume buttons (inside the view finder area). Release the pen then turn camera off again, then unplug the cord and wait 60 seconds so that the residule electric current can completely drain from the Camcorder. After 60 seconds, power on the camera and before you do anything else *YOU MUST RE-ENTER AND SET THE YEAR, DATE, TIME before you go any further. This is crucial to your camera working properly. Then power off again. Power up one more time and this time try to record and playback and see if everything works ok.
Mine worked fine. If this does not work for you it may be because you own a different model and you will need to have Sony give you specific instructions for your model.
Good Luck and let me know on this blog if it works.
Posted on Apr 22, 2009
Sony CCD-V701have a blinking arrow and camera does not record or play back
THIS MAY SOUND A LITTLE STRANGE,BUT FIRST, HIT YOUR RESET BUTTON, THEN SET THE CORRECT DATE AND TIME. THEN POWER ON AND OFFA FEW TIMES. IT WORKED FOR ME.GOOD LUCK.
Jul 14, 2010 | Sony Handycam CCD-TR818 Camcorder
Sony handy cam Hi 8 ccd trv308
Sony has a recall on some of these ccd imager problems. Contact Sony to see if your model applies, but it sounds like an imager problem on your pal format camcorder. Larry
Apr 19, 2010 | Sony Handycam DCR-SR220E HDD Camcorder
My camcorder can play old tapes but won't record
Your camcorder Sony DCR-HC20E has bad ccd imager problem and that part will be replaced to have live view to record on tape.
I can provide you ccd imager part number info if you want to repair it by yourself.
CCD Imager replacement in this camcorder requires expertise and fair skills of soldering parts in PCB.
Jul 11, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam Vision videoHi8 will record sound, but no picture.
It is known problem of bad ccd imager in camcorder and requires replacement of that part.
Sony will repair CCD-TRV318 Free of Cost in ccd imager problem.
Please click Sony CCD Imager Support for details.
Good luck.
Jan 27, 2009 | Sony Handycam CCD-TRV318 Camcorder
Tape wont play or eject.
i just read about this c:31:22 problem while looking for a solution to another problem I am having. Someone suggested removing the battery, switching the camera to the "camera" setting, and then turn it off, put the batter back in and it should work. Good luck.
Jun 15, 2008 | Sony Handycam CCD-TRV308 Camcorder
Sony Handycam CCD-FX310
Record in slow mo mode, then playback in fast forward mode ;) Problem solved. You'll see the video in normal speed.
Oct 20, 2007 | Sony Handycam CCD-TRV37 Camcorder
My Handycam corder do not record
I had a similar problem and it turned out to be my zoom was to the max. All I had to do was zoom out.
Aug 20, 2007 | Sony Handycam CCD-TRV128 Camcorder
Will not playback or record
I have a Sony handy cam ccd-trv108 Hi-8 and I can not get it to play or record, everytime I insert the tape and hit play the display screen flashes c:31.22 Please help me?
Aug 10, 2006 | Sony Handycam CCD-TRV108 Camcorder
Sony Hi8 CCD-TRV138 Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
