I have a Sharp AR-M155 and I can not print the unit says "system error L1-00 user guide" How do I fix this problem? Could you give me a step by step solution please ps i don't have a manual.
SOURCE:
SOURCE: System Error [L1-00]
Make sure the clear lock is unlocked where the paper comes out when copying.
Posted on Apr 29, 2008
  • 2072 Answers
SOURCE: Error Message L1-00 Refer to user guide
Here is the issue from the documentation.
L1:Indicates that the Main PWB sensed that the carriage did not leave home after power up or after start is pressed. Turn the machine off and on. And make sure the lamp carriage is moving. If it is not moving, Remove the platen glass, and see if you can move the lamp carrage easily, or if it's binding. Then look to see what it hindering it. If it moves freely and nothing is catching the lamp, the motor has most likely blown a fuse. But,,,,,,,,,,,,,,,,,,,, often times there the lamp is hitting the sensor that detects where the lamp should be when in the park position. You may just have to bend the bracket out of the way or make sure one of the screws on the left side of the glass are not moved down to far.
Posted on Mar 10, 2008
Benimur
  • 6966 Answers
SOURCE: printer all in one sharp ar-m155
Hi again,
Sorry but not the wire, I was referring to where the wire is attached, both ends. This would either be a clip-on or sandwiched between 2 small plates held together by a screw. It is not uncommon for this clips or plates to be tarnished or have burns. They have to be cleaned, if not current will not flow freely to the corona wire. The purpose of the wire is to draw the toner from the drum onto the paper, it uses static electricity to coat both the photoreceptive drum and the paper with a layer of positively charged ions. If the corona wire is not getting full charge or no charge at all, this is the primary reason the warming up is taking too long.
Additionally, try to enter service mode; try #, *, CA, #.
To reset the developer counter press 24, Start, 5, Start.
To exit press reset 3 to 4 times or turn main power off/on.
Would appreciate further updates.
Posted on May 03, 2008
SOURCE: Sharp AR-162 Laser Unit
searching for solve problem L6 error in the machine sharp m 160
Posted on Mar 19, 2009
SOURCE: I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
Posted on Jun 17, 2009
How to fix replace toner cartridge problem when there is enough toner in the cartridge.
Remove from the printer, give it a good shake over the sink, (you may find toner leaking and it is hard to cleanup...then replace it. That may do the trick but if it does not you may be best off replacing the cartridge. Sometimes old electronics misreport the condition of components ....it could be that the machine is getting old and going wrong. But you will only discover whether this is the case after investigating further)
Oct 26, 2015 | Sharp Cartridge Copier Toner/Developer...
AR-M155 keep complaining of change the ink cartridge.while the cartridge is working perfectly with another printer. pls what step should i take please what is the next step to take
well some times you do get bad cartridge is this third party if so replace the cartridge with a OEM. Is there a chip on the cartridge if so clean with alchol also clean the contact inside the machine where the chip connects, buy a new one OEM do not use one from other machines there chips already have data about that machine not the new one
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sharp AR-m150 refuse to copy, print and scan asking for user guide system error (H4-00)
error is sometimes a way for the machine to go into safe-mode when there is power fluctuations , or a problem with the machines thermistor or thermostat
Aug 04, 2013 | Sharp AR-M160 Black and White Copier
SHARP AR-M155 system error[H4-00]
H4-00,is a fusing troble.maybe the heater lamp is basted, or the thermistor and thermofuse are deffective.or try to cancel by a simulation 14
Jul 05, 2012 | Office Equipment & Supplies
Apr 13, 2011 | Office Equipment & Supplies
HELLO I NEED SHARP USER MANUAL FOR DIGITAL AR-M155 PHOTO,PRINTER,SCANER,AND FAX. PLEASE SEND AS SOON AS POSSIBLE
Here's the manual: http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/AR-M150-M155-_E
Click on the "Download the complete user guide."
Fill out the four question survey or put in the security code to download file.
I tested to confirm that this is the right user manual.
Thanks for using FixYa.
Mar 16, 2011 | Computers & Internet
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
Sharp AR-5320 Copier giving L 4 error alternately
The only way to corret the problem is to replase the fixing unit... That is what the L4 is refering to. It is not reading the correct tempurture..
Sep 20, 2008 | Sharp AR-5320 Black and White Copier
1,214 people viewed this question
k24674
Marvin
Marvin
