Question about Samsung TXE2746 27" TV
Trouble there is a black linen on the top of my screen and also there are some line accros the tv w/ noise but this problem is not steady it came and go
    President:
  • 3,130 Answers
I need more info please as i dont understand what your asking?? sorry
Posted on Apr 02, 2006
White lines across tv screen
Without seeing the lines I can't be sure what your set has wrong, but here are a some possibilities:
If the lines are lines are confined to the top inch or two of the screen and the picture looks otherwise normal, the trouble is bad capacitors in the vertical output circuit. Fixable by replacing the bad parts.
If diagonal lines are across the entire face of the picture tube and the picture looks washed out, the trouble is often a bad capacitor on the 200-volt line to the picture tube. This may be on the main circuit board near the horizontal output transformer, or on the small circuit board plugged onto the end of the picture tube. Again, replacing the bad capacitor can fix this.
If your TV is actually an RCA, someone may have bumped a rear-panel adjustment. On the back of the TV near the bottom right are two small knobs. RCA left these adjustments exposed inside of putting them inside the set like other manufacturers. These sometimes get bumped if someone was behind the set cleaning, or if a pet got back there and hit them with a tail. The top knob adjusts focus, and the bottom knob adjusts something called G2 or screen voltage. If this gets turned up too high it can cause the faded picture and diagonal white lines. Turn the adjustment down until a black screen looks black instead of gray.
A bad picture tube or horizontal output transformer can also cause lines through the picture. If this is the case with your set, it's time for a new TV. The transformer is relatively inexpensive but labor costs aren't, and the repair bill may exceed $200. If the tube is bad, there's no point even considering repair. The tube cost alone exceeds the cost of new TV.
Hopefully your lines are easy and cheap to fix. Good luck, and thanks for using Fixya!
Jul 22, 2011 | RCA F35673MB 35" TV
The tv has a black screen with a white horizontal line accros the screen. From where you connect you coax cable, I used to have to wiggle the cable to get video, i currently have audio but only the while...
Your problem is not in the tuner. Since you have a sound but horizontal line only and when you bump the unit the video comes out, this is only indicated that you have a dry joints in the vertical section. Re-soldering the cold solder on that area will cure the problem. Dry joints is hard to spot so you need to work with a good source of light. Vertical IC is located near the FBT and secured with the heat sink.
Hope it may help you.
Have a nice day.
Thanks for using fixya.
JDVillanueva
Jan 31, 2011 | JVC AV-27950 27" TV
Thumping
when I turn on my tv there is a black screen and a loud thumping noise.What do I do?
Jul 29, 2008 | JVC AV-48WP74 48" Rear Projection...
I have an 18 month old acer AT3220B TV - it has always had a rather loud humming noise in the background and also the volume adjusts itself?! Now I have a vertical black line down the RHS of the...
The TV reciever is capable of recieving an interference especially if your mobile cellphone is near the TV otherwise the black line which is shown on your screen is not normal,you have to sent your unit the service center.....
Jun 14, 2008 | Televison & Video
Tv trouble
MOST BE A VERTICAL PROBLEM if the line cross the screen from left to rigth,,, and if the line cross the screen from top to buttom then is an horizontal circuit problem any way you need a tech how ever if you know about tv repair and have somes skill in the campus try resoldering the vertical output IC....good luck and rate me
Jan 20, 2008 | Emerson EWF2703 27" TV
Samsung rear projection tv have vertical black linens up and on tv
you have a bad dmd module and it cost around $750-$800
Happend, because a bad soldering connections in that module. Lines will come on and off. Probably 1 day will stay on. For last 2-3 years im seen that only on hlm and hln series. Probably
happens on other models. but, i never seen that.
Is not that hard to replace that module. You have to remove 2 screws from left side and 1 screw from bottom righ side of module and 4 of them
from around dlp unit unpulg all cables ( i think
3 cables ) that it. Same way install new one in.
but you will need to adjust a module position to get picture to fill whole screen.
Jan 17, 2008 | Samsung HLN5065W 50" Rear Projection...
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Hyundai 42inch plasma tv
If these are thick black lines, this is most likely line frequency noise entering the set. you may have a leakage from the DC ground on the secondary side of the powersupply to the AC side, or a bad filter capacitor(s). Most of the time it is the filter caps that give these types of problems. If you are connected to cable TV service, or an outside antenna you can also have this problem from an AC ground loop return. Also if there is a device such as a VCR connected to the TV and it has problems, it can cause this as well...
Mar 20, 2006 | Hyundai ImageQuest DPD4210 42 in. HD-Ready...
Televison & Video Logo
50 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
