Limited or no conectivity - Computers & Internet
    Master:
  • 505 Answers
Make sure your wireless code is properly Entered> or the password witch your connecting to is corrected
Posted on Sep 10, 2008
Big pond inernet conection
- Log on as Administrator
- Start - run - type gpedit.msc
- Expand "local computer policy"
- Then expand "administrative templates"
- Then expand "network branch"
- Highlight the "QoS Packet Scheduler"
- On right window double click "limit reservable bandwidth"
- On setting tab check the "enabled"
- Change "Bandwidth limit %" to 0
- Restart PC
Hope so after performing these tips your Internet speed will be increased. If Not! Then I would suggest you to download Reginout and use its feature Internet Optimizer.
Dec 15, 2013 | Computers & Internet
When trying to connect to the internet via cord, my laptop will say limited or no connectivity. I have restarted it and started all the applications that were disabled. i also have the wireless chip for...
On the right below task bar find network conection >>> open network conection
On Local Area Conection ( cord ) right click >> properties rolls down to Internet protocol (XP) or IPv4(WIN7) click properties >>> on general tab choose Obtain an IP address automatically >>> click OK >> OK
akee_akee@live.com
Aug 16, 2011 | Dell Latitude C610 Notebook
Why does my laptop say limited access when i hook up to wifi from another computer?
OFF WINDOWS FIREWALL
THEN OPEN U R LIMITED CONECT POINT IN U R DESKTOP RIGHT SIDE
AND TCP/IP MAKE AUTOMATICALY
Jun 24, 2011 | Computers & Internet
What kind of freon does my 02 sebring limited convetible use
There is a simple way to tell. If the line conections have a male outside threaded bung, then it is R-12. If the conection resembles an air chuck fitting, then it is r-122
May 12, 2011 | 2002 Chrysler Sebring
I have a 2005 ford f 350 that we did a frame change. Now the tow haul light flashes an we have limited power.
check conection at transmision and transfer case make sur all pin are clean and straight
also corect oil is in mercon sp only for this automatic nothing else
just finish doing one for a freind landed up improper conection over transfercase
Nov 29, 2010 | 2004 Ford F350
Kenmore electric drier wont heat, worked fine yesterday,220v at machine
unplug unit and pull unit out. take back panal off.on the right side you will see the heating colom,at the top you will see thehigh limit switch you nead a continueaty meter to check if unit is bad if ther is no conection between the two conecter's than switch is bad.also at the bottom you will find the heating element and the other high limit switch check them as well. if thay check out good tha you nead to call for service call
Nov 15, 2009 | Kenmore 63942 Dryer
Accidentally conected it to 220 volt outlet
Hi, damage should be limited to low voltage power supply, I would definitely have a tech take a look at it, video-tek
Jul 03, 2009 | Toshiba 50HDX82 50" Rear Projection...
First of all try to reset you router and your pc. If it still doesn't work tell me a little more about your configuration (how many pcs, which is your router).
hope to be helpful
Riccardo
Aug 02, 2008 | 2wire 2700HG-B Router (2700HGB)
Getting on to net
Having a limited connection could mean that your laptop is far away from the router, but I think you had already tried getting closer with your laptop. At the router's web utility page see if your router is in G-only or mixed, if is not then change it to mixed (or G-only if your laptop is the only one connectiong to your router). Try again to connect to the router, if you still have the same problem then I suggest you to input an IP address and DNS manually.
Hope this works out!
Feb 16, 2008 | Computers & Internet
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
