Question about Dishwashers
Dishlex global 300 - eco light keeps flashing & dishwasher sounds like its draining & can't turn it off only at main switch
  • gippspac Sep 11, 2008
    have emptied overflow container but need to know what correct water level should be please
  • gippspac Sep 14, 2008
    thankyou for your help, problem solved
    Brigadier General:
  • 6,966 Answers
Initially, ps try:
  • unplug from the mains for say 15 minutes;
  • plug back in;
  • power/turn on;
  • press and hold the start/pause and Program simultaneously;
  • wait for the confirmation beep.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 11, 2008
  • Dishwashers Master
  • 13,433 Answers
The overflow container underneath needs to be emptied.
heres a discussion about the problem
http://forums.partselect.com/dishwasher-repair/eco-light-flashing-dishlex-global-300-a-7664.html
Hope that solves it.
Ekse
  • Ekse Sep 11, 2008
    The correct water level is when it is between the max and min marks.
  • Peter Romain Apr 11, 2012
    Helpful but a new angle, test the water overflow microswitch - To remove it take care to examine the plastic pin that secures it, it needs squeezing and pushing out at the same time. To get to it remove the kick plate first, then undo 2 small screws and tilt the next panel upwards and draw it out. My microswitch had failed short circuit. This meant that the device detected water overflow, hence eco flashing its alarm and the pump runs continuously and no water goes in.
The eco light is flashing constantly on my Dishlex Global 300 dishwasher, it is making a noise like a pump is running continously, but the unit will not operate. Can you give me some possible faults and...
The symptoms on a Dishlex Global 300 dishwasher:
  • eco light is flashing constantly;
  • noise on pump running continuously;
  • but the unit will not operate.
Possible corrective actions include:
  • water level - pls check incoming water pressure, filter, water level sensor, water valve;
  • base/bottom overflow sensor - there is a float switch in the base of the machine inside a small plastic dish. Behind the kick panel, access through a metal lid/panel/cover secured by 2 small screws. Dry completely the area;
  • Air/dry/ventilate the unit/system for a couple of days;
  • reduce incoming water pressure.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Oct 26, 2008 | Dishwashers
Our Dishlex Global 300 appears to be stuck in Pre-wash. The Eco light is flashing and the water has drained. All other buttons are unresponsive. I have just replaced the seals and handle assembly.
If your getting 120 volts to your dishwasher, I would first ohm out your thermal fuse for continuity, turn your breaker OFF to your dishwasher first.
Jul 24, 2008 | Dishwashers
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
Dishlex global dishwasher, stuck on eco, eco light flashes and drain pump runs
Try turning the taps on harder, I read that someone else had the same problem and this fixed it for them.
Aug 18, 2008 | Dishwashers
Dishlex global 300 dishwasher, eco light flashing sounds like pump noise but not working
Try taking the dishwasher out of its wall space and tipping it back and forth. Apparently the weight of water gathering in some component triggers the 'eco' function. Failing that, last time it happened to my dishwasher i waited a week for the repair guy to arrive, by which time the water had evaporated and there was no longer a problem..
Jul 26, 2008 | Dishwashers
Dishlex dishwasher global 300. Dishwasher continues to drain with ECO light flashing. Service manual says it is due to an incorrect fill level or fill line.
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Jul 01, 2008 | Dishwashers
Eco light flashing on Global 300
drained out where the float is, haven't run a full cycle yet but a partial cycle worked. i think definitely drain the float tank.
Apr 18, 2008 | Dishwashers
Dishwashers Logo
1,080 people viewed this question
Top Dishwashers Experts
