Need to find PCB for Seagate ST380021A 80GB Hard Drive
PCB went bad, drive spins up with no clicking. Looking to swap the pcb and recover the data.
Seagate Model ST380021A
Serial Number 3HV0R31W
P/N 9T6006-032
HDA P/N 100165483
Configuration Code SDX-01
Firmware 3.10
Date Code 02291 Site Code AMK
Any ideas where I can purchase one?
Thanks
  • fhenkel Jan 06, 2009
    Same problem, just a Firmware is diferent: 3.75
    President:
  • 1,114 Answers
Hi - Your best bet is eBay or other online auction. I found 7 for sale including a seller in Canada with just the PCB for sale.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 10, 2008
Hitachi simple drive
1- Good idea as long as no "clicking" currently on drive
2- Not going to be easy to get pcb alone
Oct 29, 2013 | Computers & Internet
Data recovery from a seagate barracuda 7200.10 500 GB with a PCB chip problem
You can recover hard drive data with hard drive data recoverysoftware. Thenformat the drive to get it fixed.
For data recovery software,here are two of the best Iused.
For Windows: http://www.any-data-recovery.com/index.htm
For Mac: http://www.stellarinfo.com/mac-data-recovery.htm
You can download one of them and scan your hard drive for free to previewwhether your files can be recovered. They will show you the file name, type, dateand of your files and thumbnails for your pictures that it found on yourdrive.
Sep 02, 2011 | Seagate BARRACUDA 720010 ST3500630AS PCB...
I have a 250 GB Seagate ST3250820SV Hard disk, which got damaged due to excess power supply. I have large amount of data on it. Hard disk is not detected by any of the systems. I am looking for a logic...
A common fix that may work in your case is to remove the TVS diode. Go here and search on TVS diode and read up on it http://forum.hddguru.com
For a PCB try http://www.hdd-parts.com/
Aug 04, 2011 | Seagate SV35 ST3250820SV 250 GB SATA Hard...
Require replacement power/data pcb for a seagate barracuda 7200.11 1000Gbytes part number on PCB is 2HBAHNRQ
Contact your local computer store, a computer technician/data recovery technician may have just that circuit for you to use and transfer your data onto a new hard drive.
You may also try to contact Seagate in this regard, they offer 3 year warranty on all Barracuda hard drives.
Take care!
damnor01
May 28, 2011 | Seagate Barracuda 7200.11 - hard drive -...
My Seagate 1TB SATA hard disk's PCB main I.C. is Broken & noise of Clicking and Not Detecting in BIOS.. I'm in big trouble please help me.!!!!!PLEASE PLEASE....
I am afraid the device is dead. You may be able to recover the data from a professional recovery firm but there is no other way.
Dec 20, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate ST3160215A Hard Disk PCB Card Short-160 GB ATA
Hi sunny_2003,
There are many hard drive pcb supplier such as http://www.hddzone.com/seagate-pcb-c-1.html
Be sure to backup your data.
Mar 11, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Western Digital Hard Drive AAK5000
Your HDD motor or PCB (on the HDD) blew
IF it is the PCB, you can jot down the numbers on the connector (look for this pattern: xxxx-xxxxxx-xxx-xx) and googlee for it. If you are lucky, someone selling a WD Caviar Blue WD5000AAKB - hard drive - 500 GB - ATA-100 will look at their PCB and see if the revisions match. BUY the HDD!!
You now have a 50/50 chance to get the HDD working again.....
IF the motor blew, you WILL hose the new board, and end up with 2 bad drives
IF the PCB blew, it might just surprise you and work. I have used this trick to recover data for $$$ on 8,20,60,80,160,200,and 250 WD drives that were out of warranty. Good Luck
The other option is IF the motor went bad, and you will certainly know if you see burned chips on the back of the PCB or hear a loud POP when you try the new one... You only have 3 choices.
1. Send the HDD off to a Data Recovery $ervice (No guarantee here)
2. Send it to WD for a warantee replacement (and forever lose your data)
3. Take off the HDD cover, bridge the Positioner, DO NOT TOUCH anything in there and Manually spin the HDD Platter spindle to EXACTLY 3500 or 7200rpm (depending on drive) with a tiny speed-controlled motor and a tachometer, then plug it into ext USB bridge and your PC and if the motor drive is the ONLY thing bad, the speed sense will engage, and the heads will load and you will have ~20min-2hr before the HDD dies due to contamination of the heads and platters(dust, smoke, pet hair,, human skin flakes, moisture and oxygen) so grab the essential files quick! I recommend Total Commander (Hilight all you NEED (not want - there isnt time) and drag to copy. PRACTICE TC on a good HDD. If you miss a file or folder, you will have to cancel and redo, or wait until all others highlighted are done first. Make a list - stick to it.
I have done this 5-6x so far. Several old Seagate and Maxtor 80Gb and for the larger, I Built a mini clean room, complete with forced filtered heat (hairdryer pulling its air thru a HEPA filter. for motor, I Used an expensive German variable speed dremel-like tool and cheap tach from Harbor Freight.
Good Luck!
Jan 15, 2009 | Western Digital Computers & Internet
Iomega hard drive 500gb not working
Ext USB?, Internal HDD?
Is it making any noise at all? Clicking, Whirring, etc?
If it is USB, then it is most likely hosed (or the USB enclosure is) and what I would do is go out, spend $20 at Microcenter and buy a new one - that can handle 500Gb HDD ;-)
If internal... well that is a whole nother mess.
IF it is the PCB, you can jot down the numbers on the connector and googlee for it.
If you are lucky, someone selling an identical model will look at their PCB and see if the revisions match. BUY the HDD!!
IF the PCB blew, it might just surprise you and work. I have used this trick to recover data for $$$ on all types and sizes of drives that were out of warranty. Good Luck
2. Send it to MFG for a warantee replacement (and forever lose your data)
3. Take off the HDD cover, bridge the Positioner, DO NOT TOUCH anything in there and Manually spin the HDD Platter spindle to EXACTLY 3500 or 7200rpm (depending on drive) with a tiny speed-controlled motor and a tachometer, then plug it into ext USB bridge and your PC.
IF the motor drive is the ONLY thing bad, the speed sense will engage, and the heads will load and you will have ~20min-2hr before the HDD dies due to contamination of the heads and platters(dust, smoke, pet hair,, human skin flakes, moisture and oxygen) so grab the essential files quick!
I have done this 5-6x so far. Several old Seagate and Maxtor 80Gb and for the larger ones, I Built a mini clean room, complete with forced filtered heat (hairdryer pulling its air thru a HEPA filter. For motor, I Used an expensive German variable speed dremel-like tool and cheap tach from Harbor Freight.
Good Luck!
Nov 28, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
WD 500g hard drive computer cant read it
i suspect ,if there was no bad sounds on the drive when it was wrking ,that it must be the circut board on back of drive . i ,m in the same boat myself & i,m trying to track down same type of c/board.i do not think this is mechanical bit, electrictal
soretoe
Jul 17, 2008 | Western Digital Caviar SE16 (WD5000AAKS)...
Hard drive not spinning up
Hi you would have to buy a replacement drive that works that is the same as the one you zapped and change over the board to see if you did any other damage to the drive motor or send it to a recovery person which would probably be cheaper in the long run.
peter
Jul 13, 2008 | Seagate (9Y7275557) 400 GB Hard Drive
Computers & Internet Logo
162 people viewed this question
David Payne
David Payne
