Question about Mpio FG100 MP3 Player
My Mpio FG100 is messed up! Help! Please!
When I plug in my Mpio FG100 it says USB connected but it doesn't connect to the computer. All the stuff got deleted on it and when I press play it says No CONFIG data - PL2515 util needed - Wait please but i let it sit for an hour and nothing happened so i tried to re-install the program but it says make sure your Mpio is coneccted to your pc. How do I fix this?
  • 2 more comments
  • Anonymous Jan 24, 2008
    i have the same prob, please mail me if you solve it... thanx taraquita@seznam.cz
  • Anonymous Mar 31, 2008
    The dealer told me I coul connect the MPIO MG 100 on my Vaio equipped with Vista and the latest version of WMP, but my laptop did not recognise the MPIO, which is frozen with the USB connexion sign on the screen. I unlocked the unit before plugging it.
  • djpao Jun 09, 2008
    hola no se formatii mi mpio pero me dise una cosa rara haora que debo de hacer para solucionalo aki mi coreo djpao-p@hotmail.com
  • djpao May 11, 2010
    djpao-p@hotmail.com
Lol thats not how .... switch the hold switch on, press and hold func botton press play while holding then turn on the mpio while holding after that a screen saying"preceed to format? press rec hold for N secs til screen pops up saying that its doing a low level format
Posted on Feb 20, 2008
    President:
  • 3,130 Answers
Sounds as though nyou lost the firmware in the unit and some of these can only be done at the repair factory or manufacturer
Posted on Mar 31, 2006
THE MP3 PLAYER IS NOT SOUNDING RIGHT
Posted on Dec 19, 2007
I just upfraded my Mpio FY800 to firmware 1.20, but I just messed it up a little bit on the half way through of the progress, but it still shows 1.20. My problem is when my mpio connects to the pc, it...
You may want to check with tech services from the manufacturer. I know that most electronics if there is an interuption during a firmware update it can ruin the device.
Jun 19, 2011 | Mpio FY800 MP3 Player
When I connect my FY200 to my computer, the computer does not recognize it. What could be the reason for this? Please help. Thanks in advance.
Well check your usb cord. Try using a diffrent one. if that does not work, then you should take your mp3 to a shop.
Jan 02, 2011 | Mpio FY200 Digital Media Player
I found a Mpio Fl300 player. I cannot use it because I think I need a software for it I'm guessing Where can I obtain one Thanks
now they have the fl300 and i cannot tell for sure what type of usb connection it has. As it shows on the website that there is a special usb connector the goes from usb-1/4" audio jack. But it also says it has mini usb connection. The device is listed as plug and play so if you plug it into your computer with the proper connection it will automatically connect and allow you transfer files. if it does not pop up then it is most likely the product is damaged. here is link to there website. The website is only in Spanish. http://es.mpio.com/product/productview_fl.html?view=a
Aug 17, 2010 | Mpio FL300 MP3 Player
I cant seem to fine out how to charge my mpio
do you have your USB cable? keep it connected to your computer that helps you to transfer files and charge it. device ill tell you when it's fully charged actually there is no charger for it.
if you need to read about it here is a link:
http://www.mpio.com/product/productview_fl350.html
if it works for you don't forget to rate me
thx
Apr 29, 2010 | Mpio FL300 MP3 Player
FG100 mp3 player display faded (so weak colors) are
I have the same problem with my fg100. After 5 years of usage oled became very dark. Moreover my friend experienced such a problem with his fd100 in the same time interval after buying (~5 years). It seems it is regular problem with this device after several years usage. If you know how to solve the problem pls e-mail me: tuurmr@gmail.com
Oct 16, 2009 | Mpio FG100 MP3 Player
Unreadable directory by recent windows XP laptop
MPIO Utility can be used with MPIO player that supports USB Mass Storage.
With this, you can..
- Format and Recover MPIO player
- Upgrade firmware of MPIO flash-type player
- Building playlist of MPIO hdd-type player
* Supported OS : Windows 98 SE, ME, 2000, and XP
* MPIO Utility doesn't work with FL200 and FY300.
* If you are using the latest firmware, be sure to use the latest version of MPIO Utility.
* Please uninstall the old version of MPIO Utility before installation.
[Download]You can redownload drivers and first uninstall the old one's.RICHARDM69
Sep 25, 2007 | Mpio FL400 MP3 Player
Mpio fg200
Turn off the unit and connect it to the computer.
The computer should recognize the player.
Run a program called Mpio Utility (Can be found on the CD or Mpio.com)
Select format & Config
That should do the trick.
Or go to www.mympio.com
Feb 01, 2007 | Mpio FG200 MP3 Player
Mpio HD-400 is stuck on loading screen windows doesnt recognize it
alotita, I have an MPIO HD-200. Does Windows play the sound like you have something attached when you plug it in? Or does Windows not regognize it al all? Either way, I've had to play with mine after I've dropped it a couple of times. I charge the battery all the way, then just keep plugging and unplugging from the USB wire. The last time, it took 20+ times before Windows would recognize it.
Nov 14, 2006 | Mpio HD-400 MP3 Player
Mpio not showing up on itunes
We just purchased an MPIO and we are having same issue, media player not recognizing that it is plugged in by USB, however MP3 player is.... Retailer had no clue and said the equipment was not broken.... we have another MP3 (RCA) and it works great !!... need fix
Jul 30, 2006 | Mpio FY200 Digital Media Player
Mpio FG100 MP3 Player Logo
507 people viewed this question
Top Mpio Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
