Question about Samsung SGH-D900 Cellular Phone
Moving files from pc straight to the memory card
How do you do this? It's annoying having to sync stuff to the phone then moving it to the memory card because it's time consuming and I can only do small amounts at a given time as my phone's default memory keeps running out of space.
    Brigadier General:
  • 7,752 Answers
Then you can try bluetooth the stuff it is much faster
Posted on Sep 13, 2008
I have taken the sd card out of the camera, downloaded to my computer and now the camera will not read the sd card? Please help
Hi John,
First, make sure you have the photos on the computer. Once you know they are - then you know you have a working copy of them.
The problem you're describing can be the result of MOVING the files - rather than COPYING the files. Moving is the process of moving the original files from the card and putting them on the PC - while copying leaves the original files on the card and creates a copy on the PC. If you MOVED them then you shouldn't expect to see the original files on the card any longer.
If you copied them and the card no longer shows them or if you copied or moved them and the card is no longer visible the card may have been removed before it completed the file move / copy operation. You should only remove a card / usb drive / similar device when a message pops up saying it is safe to do so.
If: 1) there are no files visible, 2) the card can no longer be read or 3) your computer says the card needs to be formatted first - you may need to do that in an attempt to make the card useable again. If you do not have a copy of the files on your PC - try to copy them to another PC before formatting the card. If you can not get copies of the pictures / files on a 2nd PC, the files / pictures on the card are likely lost. You may find utilities than can restore them however (see link below)
recover pictures from memory card Google Search
Good memory card management includes 1) copying files from memory cards, 2) verifying that they have transferred successfully *and* finally 3) formatting the memory card *in* the camera; *not* the PC. Most cameras offer options to format cards - which is superior to simply deleting files or formatting in a PC. The camera tends to set the card up for its own use - rather than for a PC's use. Formatting the card in the camera can introduce subtle differences that make it worthwhile to do.
Not as much a big deal nowadays - but older devices, cameras, etc. can read / write only to "straight" SD cards. Today, there are SDHC and SDXC types. Make *sure* that you're using the type card your camera expects. Using an SDHC or SDXC card can have unpredictable results when used in devices that expect the older, "straight" SD (no "HC" and no "XC" suffix) type cards. More details about card types can be found linked below:
Back to Basics The Difference Between SD SDHC SDXC and Which is Best for...
Jun 17, 2015 | Bell & Howell DNV16HDZ Full HD Rogue Night...
I have a memory card and i still cant get songs
First to confirm if the memory card is in the phone,
Go to the multimedia, click on my stuff, check sound, you will see the icon of the phone on the top left side of the screen and the memory card icon on the top right side.
Your songs do not go straight to the memory card, you have to receive it on the phones memory before transferring them to the memory card.
Ensure the file or song to be received is not too large, then you accept them via bluetooth or any other means of your choice.
After receiving them, you go to the "multimedia", select "my stuff", go to "sounds", select the song you just received, the you select the "option", go to "file", click on "move" to "external memory".
and your song will be loaded on your memory card.
Jun 14, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
Too much work.
you need a Data cord, connect it to your computer and you should be able to add files like any other mp3 player or flash drive.
Sep 12, 2009 | LG Vu CU920 Cellular Phone
How can I move all my files from my existing 1GB micro SD to my new 4 GB micro SD? I'm using Nokia N95.
You can try moving the contents of the 1 GB memory card in a new folder in the phone memory using a file explorer and after that you may remove the 1 GB card from the phone, insert the new card and move the files from phone memory to SD card. However, since there is a lot of data in the old card, moving the files to the phone memory is not recommended. The recommended way is to use a memory card reader on your PC, copy the contents from the old card to a location in your computer and then move them to the new card by simple copy/paste technique.
Please rate this solution in case you find it helpful, in case you need further support, do not rate the solution, leave a comment instead and I shall get back to you.
Aug 11, 2009 | Nokia N95 Cellular Phone
Inserting a 2gb micro sd mem card in lg webslider to have xtr spa
You have to move each song/file to your external memory straight away after recieving it via bluetooth because it goes straight onto your phone memory. Seach your phone memory and move all photos, videos, music etc to ext.memory by selecting the file-select options in lefthand corner- move to external memory. If your phone cannot find your external memory then you havent formatted your memory card. Go to Settings-Memory Status(way way down the bottom of list)-External Memory-Format(lefthand corner). Just remember to move each file to ext. mem. straight away.Its a pain but you have to do it manually, the phone doesnt do it for you.
Apr 21, 2009 | PNY 2GB microSD Memory Card
Transfer Pictures from Samsung A727
Try making sure that within the picture settings it is set to your memory card on the phone. If that doesnt work try moving your pictures over to the phone memory. That is most commonly why pictures can't be seen on the computer. And don't use those stupid discs you get with your phone. Use "My Computer" to view the files and stuff on your phone.
Mar 18, 2009 | Samsung SGH-a727 Cellular Phone
Help Needed With LG Prada
Have you checked the manual for any assistance? You seem to be following guidelines appropriately and I'm unsure why your still having difficulty. The proper way to sync music files is a simple as copying and pasting.
Mar 13, 2009 | LG Prada KE850 Cellular Phone
Saving straight onto memory card lg kc550
you must move files to the external memory all the time . its annoying but its the only way
Dec 29, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Cannot Sync music files
okay... :)
1. the PC needs a CD-ROM with the cell phone's drivers to help interface the sync process.
2. you could transfer the files via bluetooth if both cell phone and computer have bluetooth components built in them.
3. if the PC tells you the memory card is write protected, look for a tiny little lock/unlock switch in the edge of the card to undo the "protect".
Hope this helps...
- J.
Feb 18, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Samsung SGH-D900 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
