Question about Hotpoint Dryers
Hotpoint wd 64, wash ok tumble not heating - Hotpoint Dryers
    President:
  • 1,462 Answers
Take top off and you will see dryer manifold going across the top of machine. there are various stats mounted on the manifold. one or more may be a resettable stat ie has a small button in the middle top of the stat. press button and stat will reset. some hotpoint have instead, a thermal fuse mounted on top of the manifold in a sleeve. this may have gone open circuit so check with a multimeter
Posted on Sep 10, 2008
Cycle wont move on withhotpoint 220
check the heater once its filled it will stay in wash until it heats to the correct temperature so if the heater has failed it will stick in programme
Feb 27, 2014 | Hotpoint Washing Machines
Not heating up
first thing to check is the heating coils,,if ok go to the censor just over the top of the door,,,this is most likely the dud part
Jul 10, 2010 | Hotpoint Dryers
Hotpoint dryer not heating, dryer tumbles but no heat.
check the switch is working then go to the heating coils and check there working ok the next thing to go to is the heat censor inside above the door if this is not working you wont get any heats at all,
Jul 01, 2010 | Hotpoint Dryers
Hello I have a hotpoint tcp 1p tumble dryer
this sounds like the thermostats
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Dec 20, 2009 | Hotpoint Dryers
Aquarias wd 420 hotpoint
sound like motors or heaters have a short good luck.
Sep 13, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Runs Cold no heat ? Tumble Dryer
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Free tumbledryer repair videos
We have a Free full video library on appliance repair video’s
Jun 06, 2008 | Frigidaire 14 Cycle Tumble Action Washer
No heat on tumble dry programme. Display flashed F 13.
You need to replace the heating element for the dryer which is positioned on top of the outer drum. Remove the top cover of the machine and locate the heater.
Nov 01, 2007 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
109 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
