Question about Sanyo DS20930 20" TV
Broken television? My t.v. will not stay on. ....I was in the middle of watching my t.v. and it just switched off. When I go to turn it back on it will only stay on for 5 seconds and then turn right back off. I haven't even had it for a whole 5 years yet...What is the problem?
  • 1 more comment
  • deedee37 Oct 24, 2008
    t.v will not stay on 5 min and its only 3yrs old
  • rhebert1995 Jan 12, 2009
    I have a DS20930 television. Just today I have had a problem. When the power button is pushed the t.v. audio comes on for approx. 3 sec. then the t.v. powers down. This can be done 3 times before it won't power up again. If I unplug the unit and then plug it back in, I can do this 3 more times. I did notice when plugging the t.v. back in it sounds as though there is an instant power draw.
  • sticks_mcgee Apr 16, 2009
    Turned the tv on and got bad colors and bad sound-then everything went blank-no power-no nothing-Bought at Walmart 4 years ago but it is in my bedroom and not tmany hours on tube---want a refund
    Champion:
  • 252 Answers
Try to re solder your tv.,coz mostly the defect of tv. is only a lose connection., but be care of short circuit
Posted on Oct 01, 2008
Screen went blank in the middle of watching. I turned off. But now when I turn it on the green light Blinks fifteen times n stills stays blank..
It is interesting to me many people who today post questions do not have a brand and model number: those are really needed to try to provide some real help, can you?
Dec 10, 2012 | Televison & Video
Hi..pls..help..my jvc television, im watching then turn off have a power but sadly it has a line at the middle of monitor and turn off.
You have a vertical amplifier failure or dry solder on the vertical IC. When cold if the TV works for some time and then you are getting a thin white line in the middle of the screen after some time -- its a dry solder problem. The vertical IC runs very hot in the TV and develops dry solder after a few years.Will run when cold and switch off when hot.
Are you well versed with electronics to do the repair yourself ?. If so, revert back and I will guide you if you mention the TV model #.
Apr 11, 2011 | JVC Televison & Video
Tv turns off while watching it stays off a couple
Sharp 60" DLP 1080i , while watching cable, the show blinks off and on. but if we play video games or watch DVD's it works fine. what is wrong?
Jun 23, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
My Insignia tv keeps defauting to Video1 screen every minute!!!
Turn off your television. Try disconnecting all external signal sources (except the antenna or cable) from your television.Turn on the television and see if this resolves the problem. If it does then you may have a faulty cable connection to your television. Change out the cables one by one to find the bad cable and replace it. If this does not solve your problem. Turn off for a period of hours(This may allow your television set to reset itself) and test again. If you still have the same problem, Then you need to call customer service for servicing and technical advise. Call this number for service : 1-877-467-4289. Hope this helps you with your problem.
Apr 07, 2009 | Insignia LCDTV26 26 in. Television
Philips 42" plasma just died
Had same prob. R/R powersupply board. ($100+/-) Easy fix if you can run a screwdriver.
Oct 27, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
No power
I'm having a very similar problem, basically its a fuse that is blowing out, I think the transformer is sending too much power it's way.
Jun 14, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Mitsubishi VS-50800 on/off problem
It sounds like, and I'm only making an educated guess here, but I'm thinking your television is broken and you should probably get a new one if you want to continue watching television.
Oct 21, 2007 | Mitsubishi VS-50800 50" Rear Projection...
Sanyo DS20930 20" TV Logo
71 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
