Question about Konica Minolta magicolor 2300DL Laser Printer
Fuser How do I change the Fuser?
  • 38 Answers
Do You have the the mechines schematics?
Posted on Apr 30, 2006
How to fuser chnge
1. remove the cover for the duplexing drawer below the fuser drawer.
2. extend the fuser drawer
3. remove the 3 front covers of the fuser drawer
4. remove the three black screws that secure fuser motor,
5. remove the yellow cover to access then two screws that secure the fuser unit to the drawer.
6. unplug the connectors you see in front and the one below the fuser unit.
7. fully extend the drawer and push in the leaf springs you see and pull the drawer out further
8. remove the two screws you see on the top of the fuser and remove the fuser unit- gently.
Good luck
Jul 11, 2014 | Canon LASER SHOT LBP 3300 Printer
50.9 fuzur error hp 4515
it seems like fuser problem
* turn off then turn on
* check fuser connector.
* reconnect fuser again
* if the problem persist again then change the fuser
before changing fuser check maintenance kit, if it is near 225000 then change maintenance kit
Jun 27, 2013 | HP P4515n LaserJet Printer
It gives a code sc 542
The error code is related to the fuser area.
Likely to be a low fuser temp issue.
Need to verify good or bad heat lamps.
1) Check each lamp in fuser.
(lamp is good if you get continuity)
(lamp is bad if open)
2) Check the thermostat. (thermal control device)
(triggers if unit gets too hot)
3) Also check thermistor (monitors temp of fuser)
(2) total (middle and rear)
If heat lamp is good:
Your best bet is to change all three items. (Temp fix)
Fuser thermostat - thermal control device
Fuser thermistor (middle front) - thermal control device
Fuser thermistor (rear) - thermal control device
These items wear out. Change at the same time.
Fuser needs to be rebuilt or replaced.
Oct 19, 2010 | Ricoh Aficio AP610N Laser Printer
Verticle lines printing on laser printer
Check the fuser. If it is the fuser, you should be seeing 3 dark lines on the fuser film. Here is the picture about how the film looks like:
Changing the film usually solve the problem. However changing the film itself is difficult. You have to remove and basically disasseble the fuser, and change the film. However it is fairly cheap and if you decide you would like to save some money, here is the link available in ebay:
http://cgi.ebay.com/Fuser-Film-Sleeve-HP-LaserJet-P3005-RM1-3740-/250558576965?cmd=ViewItem&pt=BI_Toner&hash=item3a56747945
Or, simply search for 'P3005 Fuser Film' and you will find a lot.
Other than that, you can change the entire fuser. Please note that fuser for P3005 is not consumer installable part. You still have to take out some parts in order to change the fuser.
The parts are available from many parts supplier. Simply google 'P3005 fuser'. Usually around $100 for a refurbished fuser.
You can also recycle your old fuser and get some moeny! (about $15-$25 per fuser).
Apr 09, 2010 | HP LaserJet P3005n Printer
We have put a new toner in but still we are experiencing lots of horizontal lines??
Nov 17, 2009 | HP LaserJet P3005n Printer
Changed power supply from 110v to 220v, now get 50.2 fuser error
The printer will have a 120v fuser, unkess that has been changed for a 220v fuser, it won't get up to temprature on 220v, hence the error message.
It needs a 220v fuser.
May 05, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
Need to change out a fuser kit
1. Turn the printer off.
2. Open the top cover.
3. Grasp the purple handles on the fuser.
4. Remove the old fuser from the printer.
5. Install the new fuser.
6. Close the top cover.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00366229/c00366229.pdf
Mar 20, 2009 | HP LaserJet 4700 Printer
Hp 3550 fuser problem
try this
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support
Oct 29, 2008 | HP LaserJet 3550 Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
178 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
