Question about Gateway LCD17TV 17 in. Television
Lcd tv Hello. I have Gateway flat TV: GTW- L17M103, also I have audio but I have no video. Any ideas? Thanks.
  • 5 more comments
  • geoffy Nov 09, 2007
    I've got an Arae 40 “ LCD Model number ELT-4000 AP. No display but all other functions OK. I have had the inverter boards checked professionally with no fault found. I have checked the psu on all outputs and they all check ok.
    Only thing left I am told is the lamps, whats the best way to check them ? Do I need any special equipment (anything over a multi-meter defeats me).
    Thanks in advance.....
  • mrjp Dec 10, 2007
    Can anyone tell me where I can purchase the 56uf@25v capacitors for the gateway lcd 17tv
  • Anonymous Dec 24, 2007
    TV is working...trying to us dvd...We have audio, no video...
    same problem with a camera...we have audio, no video...
    We have used both before and now the video out doesn't seem to be working...
    Are the video inputs out?
    We bought this tv only October 28th.
  • millbroc May 16, 2008
    18 inch LCD with slight, but darken video, but no picture.
    Thanks
    Freddie
  • Anonymous May 31, 2008
    just out of the blue the screen went black while we were watching it ,all channels no screen.
  • campupnorth Sep 01, 2008
    i have a lcd hitachi 50v720 just watching the tv and it went blank no pitcher no sound temp lamp blinking and lamp indecator blinking continiuesly could you help me fix it
  • kmboone Feb 04, 2009
    i have a gateway 13" lcd model gtw-l13m103 i have sound but no picture just a light
  • 558 Answers
Blown capacitors on the inverter/ vga board
Posted on Apr 27, 2008
All problem can be fix by checking the bad contact of the parts. re soldiering it will back good.
Posted on Jul 20, 2008
YOUR UNIT IS PROBABLY IN THE PROGRESSIVE MODE. CHANGE TO INTERLACE ON REMOTE OR INTHE MENU.
30 YR TECH
Posted on Mar 05, 2008
To solution #2
My TV has  the same problem. Where can I get the parts for backlight/lamp and capacitors?
Posted on Dec 22, 2007
To solution #2
My screen was very dim on the left half and totally dark on the right half. I pulled the lamps and sure enough both the top & bottom lamps were half lit. On the Backlight Display Driver Board are two Electrolytic Capacitors 56uf @ 25v. I replaced both capacitors and lamps are now working properly! Total cost of parts, under two dollars.Solution # 5 was absolutely correct. Thanks!
Posted on Oct 21, 2007
  • DANDILEE Oct 21, 2007
    I didn't realize Solution #'s incremented. The solution preceding mine was correct.
    Thank You JMITSOULIS For Your Posting!
Please do the following: when turn the unit on, Carefully see the screen response,i.e., any bright screen comes on then off? or never has any light in screen. If screen is bright and than off, it indicates that the backlight is faulty. In this case you need to replaced the panel or get back light fixed. Deshan_lu@thomas.com.au
Posted on Aug 28, 2007
  • 3 Answers
What do you have hooked up to it? make sure there arent any special features on a DVD player (such as progressive scan) that your other components might have, but this TV doesn't
Posted on Mar 22, 2007
    Problem Solver:
  • 6 Answers
Gateway have 2 capacitors in the inverter those need to be replaced
Posted on Jan 19, 2007
    President:
  • 3,130 Answers
Have ya dropped the display or has it fell recently?? if not sheck the back light curcutry
Posted on Apr 02, 2006
I've had mine fixed now. Spent nearly 2 months trying to get it sorted and had to eventually give up under pressure from the wife who was fed up of having the projector set up in the living room !!!
I used a local company who had it running in 2 days telling me it was a 'LCD controller board', whatever one of them is.
Posted on Jan 02, 2008
    Sniper:
  • 80 Answers
The most frequent problem in this set causing this symptom is one or more lamps failing in the backlight assy. If the set lights momentarily and then goes out, the backlight shutdown circuitry is detecting a bad lamp and shutting down the inverter that powers the baclight. Have a qualified service facility check the backlight assy for a failed lamp or inverter module. Good Luck. Joe Weibel Custom Electronics Memphis, TN 38133 (customelectronics.org)
Posted on Feb 12, 2007
4 Suggested Answers
  • 3 Answers
SOURCE: screen changes between color as a demo function.no signal
Gateway was sued Class action over LCD's and Plasmas they sold over a 2 year period. They resell 3rd party TV's that were very faulty, an immature design.
Here's what I learned about mine, which makes it limp through as a Computer monitor (both DVI and VCA) and halfway functional TV.
You have to connect a DVI source, on the Main Menu for the DVI input there is an option called "Factory Mode". scroll down to it with the CH buttons and select it with the vol button. The scroll to "initialize eprom", select and confirm it. After the "Waitting" words disappear, make sure you have a TV source connected, Then turn the TV off and on, using the hard switch in the back. The TV input should be defaulted to channel 10 or 11 now But you select a TV channel that has no TV signal on it (like channel 1 for example) , the whole TV input side will refuse to let you select it again, and you'll have a blank screen and have to start over.
That takes care of the blank screen thing Now the other problem is parental control is defaulting to "ON" or something, and you can't program channels. With the TV input Main Menu engaged, select "Setup Menu." If you have this problem, then you'll only see 2 options, all the TV input and channel programming options will be missing. You have to select Parental Control, and when it prompts you for a password hit the volume > button 4 times (or just wait for a minute.) This should bring back your TV System and auto prgram/manual search options.
Unfortunately, my TV doesn;t remember these setting very well if I select cable, it does better if I select "AIr". But at least it funtions - kind of. If you switch to your computer input, you probably will have to switch the monitor off and on from the back panel again. Mine always starts up with the menu onscreen. All this might bve less trouble if you have a the remote, I don;t know where mine went after the last move.
Good luck, and hope this helps.
Billy K.
Posted on Feb 12, 2009
SOURCE: gateway gtw l17m103 light out
For the solutution repair of the Gateway Model GTW-L17M103 TV 1/2 lit screen - I was told by a local authorized Sanyo Flat Screen Repair shop that the lamp or bulb is going out and needs to be replaced. He said the replacement would run around $125. I have the same problem as well and now am seeking to purchase a lamp/bulb.
Posted on Feb 21, 2009
stonephoenix
  • 563 Answers
SOURCE: The screen on my Gateway Plasma 42 in TV went
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. The question will be, is the part still available? Before paying a TV repair person $75+ to diagnose the problem, ask yourself if you're willing to pay $250 minimum to fix this particular set. Also keep in mind that most TVs that old have a very limited number of replacement parts still available. Normally it will cost at least $75 to have the set looked at by a repair shop (diagnostics). If the part needed to complete the repair isn't available, you won't get that money back.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
No picture or sound
Check the input, make sure you have audio and video coming in. Also verify that you have the TV set on the right input.
Jul 21, 2009 | Gateway GTW-P42M303 42 in. Plasma...
A Gateway GTW-L17M103 will not power on, no power lights/menus.
Have you read the manual for trouble shooting? Is there a reset button on the unit?
Screen brightness is diminished?Video display devices experience degradation of brightness over the life ofthe device. Normal brightness degradation is not covered by your warranty.
You cannot see a picture?Make sure that the power cord is plugged into a grounded electrical outlet.?Make sure that the power button is turned on.?Make sure that the selected input source is connected to a working inputsource.?Press thecorrect input source.?If your LCD TV is connected to your computer in RGB or DVI mode, pressany key on your keyboard to "wake" your computer.You see a distorted picture or hear unusual sound?You may be getting interference from electrical appliances, cars,motorcycles, or fluorescent lights. Try moving your LCD TV to anotherlocation.The color is abnormal?Make sure that the input source cable is connected securely and correctlyto the back of your LCD TV.
Get schematics and look for fuse and voltage points
Feb 28, 2017 | Gateway LCD17TV 17 in. Television
Gateway gtw l17m103 light out
Dec 17, 2008 | Gateway LCD17TV 17 in. Television
GTW-L17M103 LCD TV
perhaps a computer repair shop .
Dec 11, 2017 | Gateway LCD17TV 17 in. Television
Digital HD Coverter will not change channels with remote when plasma tv turned on
Flat batteries in the remote? Batteries the wrong way around in the remote? Corroded battery terminals in the battery holder?
Jan 31, 2018 | Gateway GTW-P42M303 42 in. Plasma...
GTW-P42M403
I actually bought the 5 year warranty when we purchased this new and it was still under warranty. Gateway is sending us a brand new TV. No need for me to try to fix this, but thanks to all involved.
May 29, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Gateway LCD17TV 17 in. Television Logo
829 people viewed this question
Top Gateway Televison & Video Experts
Ronald
Level 1 Expert
Marvin
Marvin
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
