Question about Sunlight Supply 400 Watt Hps Sunsystem I Sun Gro Plant Grow Light
Unplugged Hood power cord
I was recently moving my ballast and the power cord that goes into the hood unplugged while the power was on and then I plugged it back in while it was on and now the light wont come back on. Did I blow the bulb or is their something else run.
    Problem Solver:
  • 8 Answers
More than likely , if you haven't tried it since you found it would not work after plugging it in again , it will work after it cools and will restart the lamp . The ballst is designed not to restart right away to protect the components and bulb . Usually after about 10 mins of killing the power or turning off the switch or timer and reconnecting the cord , the fixture will work again . Try that ! John
Posted on Sep 27, 2012
    Problem Solver:
  • 5 Answers
YES THE POWER BEING SHUT OFF THEN ON WITHOUT THE LIGHT SWITCH BEING INTHE OFF POSITION BLEW YOUR LIGHT BULB. IT COULDN'T BE ANYTHING ELSE UNLESS YOUR CORD HAS A FUSE. CORDS WITHA FUSE ARE FAT AND ODDLEY SHAPED AT THE END U PLUG INTO THE LIGHT.
Posted on Oct 05, 2008
My burglar alarm goes off and on all night. What is the solution
The most common sensor that goes bad is the hood (bonnet) switch. Open the hood and look to the left of the microfilter housing. Circled in red is the switch (looks like a button). Unplug it and see if it solves your problem. You can leave it unplugged with no adverse affects.686c34d5-14d9-4ce2-9928-f2d06f7bf364.jpg
Mar 27, 2014 | 2005 BMW X5
NfoI am having problems with the display do not function properly. I have done what the instructions suggested by unpluging the power cord. I also have tried to adjust the magnet and reed switch. Still...
Dear Sir:
I will help you.
Please follow the step, carefully .
Some consoles require batteries. Check to see ifthis is the problem. If the console does not use batteries, move on to Step 2.
    • 2
Remove the key from the console.
    • 3
Unplug the power cord.
    • 4
Remove the screws from the console hood andremove the hood.
    • 5
Turn the pulley until the reed switch and magnetare aligned with a 1/8-inch gap between reed switch and pulley.
    • 6
Replace the hood.
    • 7
Plug in the power cord.
    • 8
Reinsert the key into the console.
    • 9
Run the treadmill to check for a correct speedreading. This may take a few minutes.
Please reach me, if you have continuing problem.
Thank you in advance, sincerely
E.CUADRA Managua, Nicaragua. C.A.
Sep 13, 2011 | Proform 490 C Treadmill
Hi my 2006 x5 4.4l , recently the alarm the flasher lights goes off while its parking, sometimes it happans twice a day or sometimes once every three to four days, can anyone help please?
hi bayan,
There are numerous inputs that are monitored for BMW anti theft deterrent system. All the door locks, interior sensor, hood switch, and inclination sensor can cause the alarm to set off. I would recommend making sure all your door locks are working correctly. Next I would check under the hood and make sure the hood switch is not broken or out of adjustment. I think usually the switch can be located on the plastic cowling in the vicinity near the driver side strut tower. When you find the hood switch, you can just unplug it for testing purposes. Leave it unplugged for a while and see if you still have a problem. If nothing seems apparent you can always have the system scanned to see what faults are stored in the control unit's memory.
Jun 30, 2011 | BMW X5 Series Cars & Trucks
There is no display light anymore.
Some consoles require batteries. Check to see if this is the problem. If the console does not use batteries, move on to Step 2.
    • 2
    • 3
    • 4
Remove the screws from the console hood and remove the hood.
    • 5
Turn the pulley until the reed switch and magnet are aligned with a 1/8-inch gap between reed switch and pulley.
    • 6
Replace the hood.
    • 7
    • 8
    • 9
Run the treadmill to check for a correct speed reading. This may take a few minutes.
Feb 19, 2011 | Proform XP Weight Loss 620 Treadmill
I have 2002 Honday Odyssey. Recently, the alarm goes off randomly. Is there any way to permanently disable alarm? Thanks.
No, but your problem might be located in the hood latch. Try unplug hood latch harness(letter A). If alarm return to normal leave it unplug or replace hood latch(letter C). Alarm system should work normally if you leave harness unplug. good luck.
Dec 13, 2010 | 2002 Honda Odyssey
My friend has a WD-65731 Mitsubishi; a week ago the image wouldn't come , so he unplugged the power cord, plugged it back and the image came. But, he wasn't able to turn it off from the remote any longer,...
try this wait until the blinking stops and then press the button. if still not working replace the lamp and lamp ballast. before changing lamp make sure you clean the dust out using a compressed air.also clean the small fan over the lamp ballast.
Sep 10, 2010 | Televison & Video
Keep blowing fuse under hood when i put power wire in to amp
disconnect the negative battery terminal, replace the fuse with all the wires hooked up to the amp and reconnect the battery terminal, that way the initial surge of power goes through the negative terminal and not your inline fuse. That should solve your problem.
Mar 29, 2009 | Pioneer GM-5200T Car Audio Amplifier
Light bulb socket replacement for a really old Air Fare kitchen hood
The chances are that your range hood light socket was fully impacted with grease from cooking. Shut the power off to the range hood or, in many applications, simply unplug the power cord. Remove the socket. Get a spray can of electrical parts cleaner and saturate the socket through the tiny pin holes you may see at back of socket. shake out all of the cleaner fluid. Somehow hang the socket up with bulb base facing up all night. Hook it up. That might solve the problem.
It worked for me very recently on a 20 year old range hood.
DON'T USE ANYTHING OTHER THAN AN OFFICIAL ELECTRICAL PARTS CLCEANER. Most hardware stores, etc., have it.
Jul 23, 2008 | Kitchen Ranges
Infocus 250 projector won't power up
Urinate on the bulb. This sometimes lubricates the contraption that the bulb connects with and it usually comes on instantly.
Mar 23, 2008 | Office Equipment & Supplies
Sony kdf-50we655 tv will not turn on
you will need to replace the lamp ballast. part number A-468-798-14
Nov 06, 2007 | Televison & Video
Sunlight Supply 400 Watt Hps Sunsystem I Sun Gro Plant Grow Light Logo
251 people viewed this question
Top Sunlight Supply Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Sunlight Supply Garden Expert? Answer questions, earn points and help others
