Luhr Jensen Big Chief 9890
Problem for Luhr Jensen Big Chief 9890
Big chief smoker
By kathosmit on Sep 10, 2008
electrical cord melts on to smoker. I have replaced cord, only to have it happen again. Not sure I can remove it this time. What could be causing this problem?
Comments:
Sep 10, 2008
- It isn't actually the cord, but the plug-in that melts. Could something be wrong with the heating element, or is there an intermediate part between the two?
Sep 11, 2008
- I replace the heating element and the cord, and from now on, I WILL keep the contact points clean. Thanks.
Same Problem
Dec 20, 2008
-   Where can a buy a new element and cord?
-   nickwolfe
Nov 26, 2008
-   The plug to the smoker is partially melted, I need a replacement cord that works with the smoker. Standard cords do not work. Where can I buy the replacement cord for Luhr Jensen smoker. (front loading). -   julewo
Best Solution
posted on Sep 10, 2008
Helpful)
Iceboxman
Rank: Master
Rating: 86%, 11 votes
Somethings not right, the rubber part of the cord should be outside of the unit and not touch ANY hot surfaces.
Comments:
Sep 11, 2008
- If you get it repared this time, clean , the contact points in the socket and the pins on the heat element with rubbing alcohol, let dry before using . Keep the contact areas clean and shiney.
Was this helpful?
Yes
No
Solution #2
posted on Feb 18, 2009
Very Helpful)
Innov8
Rank: Apprentice
Rating: 100%, 2 votes
I am on my third cord. I love the smokers, and own 2 but the cord design stinks. You can clean the contacts all you want, but one always heats up, gets soft, loses its spring, and causes a weak contact. When that happens, it arcs, melts, and finally burns out. You can google "smokehouse cord" and find suppliers from $17.00 to $23.00 (smokehouseproducts.com). I'd like to hardwire a solution or make a replaceable head. If somebody has a good, safe design for this, let me know.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Luhr Jensen Big Chief 9890
Questions and Unsolved Problems for Luhr Jensen Big Chief 9890
Do you recommend Luhr Jensen Big Chief 9890?
Answer
Answer
gfci triggered on 2 separate circuits when new-in-box front load model o plugged in. element? ... (More)
Answer
I am trying to find a copy of an instruction manual for the Big Chief 9890 top load model
Answer
where can i download a manual on a big chief smoker?
Answer
every time i plug my big chief in it starts to to heat up for a minute then it blows my curcut .any... (More)
Answer
WHere can I find basic instructions for luhr jensen big chief?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Luhr Jensen Big Chief 9890:
Top Grill and Smoker Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Grill and Smoker Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
