Philips Magnavox 27MS343S 27" TV
Problem for Philips Magnavox 27MS343S 27" TV
No Picture, sound is all static
By Tipper on Mar 30, 2006
TV comes on, shows channel numbers, as you change them. Volume goes up and down. Screen is Black with white snow. We do not have cable, but have an antenna. Other tv's in home work fine. TV fine last time it was watched. Turned it on and got this. Glad for any advice you can give.
Thank you
Same Problem
May 21, 2008
-   will my problem is no picture no sounds just blue screen with white horisontal interlaze, by the way my tv is lg 21inch flat screen-   willoy
Best Solution
posted on Mar 31, 2006
Helpful)
techman
Rank: Guru  Philips Expert
Rating: 86%, 7667 votes
Make sure the ant. input switch didnt change and check the ant. connections If that dosent work sounds like a defective tuner.
Was this helpful?
Yes
No
Solution #2
posted on May 25, 2006
Somewhat Helpful)
wolfg
Rank: Master
Rating: 78%, 14 votes
CHECK YOUR VIDEO INPUTS. THE HD SIGNAL IS TAKING OVER ALOT OF THE ANALOG SIGNAL.MAYBE A STRONGER ANTENNA OR ADJUSMENTS MIGHT WORK AS WELL.
Was this helpful?
Yes
No
Popular Solutions for Philips Magnavox 27MS343S 27"
Questions and Unsolved Problems for Philips Magnavox 27MS343S 27"
Do you recommend Philips Magnavox 27MS343S 27" TV?
Answer
Answer
on a magnavox 42mf231d/37 plasma tv where is the ceramic capacitor 561k 2kv? i know it is next to... (More)
Answer
my Tv IS TOSHIBA CT-871 HOW CAN I USE THAT REMOTE TO TURN THE SUBTITLES ON?
Answer
My 27" tv will keep turning off after a few seconds after turning on. sometimes takes like 20... (More)
Answer
it is blinking a code how do i find out whats wrong with it there is a 1 maby 2 second TIME ELAPS... (More)
Describe your Standard Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in Van Nuys, CA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
