Question about Samsung MW1030WA Microwave Oven
My micorwave my samsung microwave dislplays 88888888888 and is not working. i need your help please. thanks.
  • Samsung Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
More info on such problems:
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
Always spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Always use the vent fan when cooking on the stove top to keep steam and grease out of the controls.
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
I recommend a soft cloth since paper towels can scratch the plastic.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
Posted on Sep 16, 2008
Is there a fuse in my microwave and where do i find it
Hi Christa.
Please allow me to try to help you.
Most microwave fuses are 1 or 2 inches in length. All you have to do is unscrew the outer cabinet and you will get to the fuse.
I have attached a video that could be helpful to you in getting to understand what needs to be done to find the fuse of your microwave.
Hope that helps.
Best wishes. Regards.
Nov 06, 2017 | In Microwave Ovens
Just replaced ite control board on my microwave and got all my buttons to work, but now the clock display is dim in the middle only.
please follow the troubleshooting chart attached and proceed with common sense: God bless you
Jul 19, 2012 | Microwave Ovens
Micorwave is not heating.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Nov 04, 2010 | KitchenAid KCMS185J Microwave Oven
I need a replacement plate for a goldstar micorwave model ma-101w2. What is the part # for this plate?
I found your glass tray listed at repairclinic.com. The part number is 1194865. The price is about $35. If you have questions, or need further assistance, please post back and let me know. I hope this helps you.
Jun 28, 2010 | Goldstar MA-1012 Microwave Oven
RCA Model RMW700 micorwave 1 yr old stopped working. No power, yet the outlet is live. No power to the display, no light inside, just dead. Stopped working when heating cold cup of coffee.
There is a fuse inside the cover of the microwave. You will need to remove the outer shell and follow the power cord you will see an inline fuse. This fuse can be purchased at any appliance parts house.
Hope this helped
Dave
Jan 19, 2010 | RCA Microwave Ovens
Microwave wont heat food. Everything else works.
Micorwave doesn't work when the megatron tube is out. That's probably why it won't heat up. Either replace microwave or the tube. You can get the number from Sears for the megatron tube by calling customer support.
Nov 09, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Have a whirlpool mh7130xez over range micorwave, everything works great but the suface light? beeps when i push the button? tried 3 new bulbs---please help
The relay for the lights is not working. No board level repairs. You will have to replace the control board to get this feature back.
Eric
Sep 01, 2009 | Microwave Ovens
My micorwave
Hi and welcome to FixYa,
Your described problem indicates that the logic circuitry in the main controller board is faulty. Since the logic circuitry is integral to the board, it would require an assembly replacement. On most brands/models, the main controller board is directly behind the display panel. In some instances, it could be a stuck key/button hence the logic would not reset.
Good luck and thank you for using FixYa.
Feb 13, 2009 | Samsung Microwave Ovens
Panasonic microwave oven NN-S235WF modle
just replace micorwave power out let.
Dec 30, 2008 | Microwave Ovens
Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Jan 14, 2007 | Whirlpool MH7135XE Microwave Oven
Samsung MW1030WA Microwave Oven Logo
175 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
