Geforce 7900 driver problem.
I have a geforce 7900, I'm not sure which model. I have had it for years, it has always worked perfectly. I recently reinstalled windows xp on my desktop and when I went to reinstall the driver for it, it makes the quality (resolution) very very low (800x600) and everything becomes very grainy, almost is if there is wayy too much contrast to everything. It will not allow me to change my resolution settings either even though it asks if I would like windows to do it for me because the settings are so low. It won't even fix itself. I have gone into device manager and uninstalled the driver and then reinstalled it several times.. but still the same thing. Any suggestions would be greatly appreciated. Thank you.
  • Christopher Croft Sep 10, 2008
    http://downloadcenter.intel.com/filter_r...*+XP+Professional&lang=eng&strOSs=44&submit=Go!
    I used that website to install the chipset drivers for my Intel D946GZIS motherboard.
    It shuts down every time saying "Intel Chipset Device Software installer has encountered a problem and needs to close. We are sorry for the inconvenience."
    >,< what now? o.0
    Successfully install chipset drivers thanks to you but that didn't help. Once I reinstalled driver I had the same problem.
    Then I found a different site and downloaded an outdated driver from 2006 (as you recommended) Fixed EVERYTHING! Works perfectly all thanks to you!! 5 Stars! "FixYa!" rating!
    Now, thanks to you and FixYa, I have proper updated drivers and everything runs smoother than ever!
    I only wish I could give you a higher rating... Thank you so much for helping solve this irritating problem and good luck to you in the future!!
Will this solution solve possible overheating problem? I am getting alot of large polygons during game play. it worked fine but then it went downhill. Ive had it for a couple years, but I dont know how age would change anything
Posted on Dec 17, 2009
    Brigadier General:
  • 6,966 Answers
If re-installing the GeForce 7900 driver does not correct the problem it may be because you need to install first the AGP port driver of the motherboard. In some motherboards, this is part of the chipset. In the case of VIA chipsets, the AGP driver (not the video card) is part of the 4 in 1 driver set.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 10, 2008
  • Louie  Role
    Louie Role Sep 10, 2008
    The same also holds true for Intel chipset motherboards. Incidentally:
    • Intel has ChipUtil that is meant to determine/verify the actual chipset used in the motherboard;
    • Intel has infinst_enu.exe that is meant to update/inform the OS how to handle the chipset used in the motherboard including the AGP port;
    • Intel has Intel App Accelerator Driver.zip that is meant to update/inform the OS how applications would best be run.
    With all of these in mind, again perhaps your best bet is to find out the chipset driver for the D946GZIS motherboard, download and install. Additionally, it may be to your advantage to install an older version of the NVidia driver such as the 56.72 or any of the 2006 dated drivers.
Hey, I'm trying to play World of Goo, but after
Yeah, with World of Goo especially, sometimes having previous drivers makes them playable.
Try installing these drivers and see if that helps.
May 23, 2011 | NVIDIA GeForce 7900 GT
Hello, I need driver for u.s.robotics model : 7900 thanks.
You can download the drivers from the below mentioned Links
but you have to check which model is yours
(with one light its USR-7900, With two lights its USR-7900-01)
USR-7900 DRIVERS usr7900_XP.zip
USR-7900-01 DRIVERS USR_7900-01.zip
Feel free to reply to this post if you require more assistance
Regards, BA
Jan 13, 2011 | U.S. Robotics USR-7900 (5 Packs)...
BFG GeForce 7900 GTO/PCI-E 16
well firstly this card is not direct x 10. I'd say get a new card, the geforce 9600gt is a good performer for the price or an ati 4850 which is a bit more expensive
Apr 25, 2009 | Evga e-GeForce 7900 GT CO SUPERCLOCKED ,...
I have a e-GeF0rce 8600 GTS. My computer sees a NVIDIA GeForce 6150SE N FORCE 430.0. iS THIS A PROBLEM
Hello Baldarchi,
This is normal and how ever uninstall the current driver and install latest driver from the following link:
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/Nvidea%20video%20driver.exe
The above driver supports:
[DEV_0098] NVIDIA GeForce Go 7800 [DEV_0099] NVIDIA GeForce Go 7800 GTX [DEV_00C8] NVIDIA GeForce Go 6800 [DEV_00C9] NVIDIA GeForce Go 6800 Ultra [DEV_00CC] NVIDIA Quadro FX Go1400 [DEV_0144] NVIDIA GeForce Go 6600 [DEV_0146] NVIDIA GeForce Go 6600 TE/6200 TE [DEV_0148] NVIDIA GeForce Go 6600 [DEV_0149] NVIDIA GeForce Go 6600 GT [DEV_0164] NVIDIA GeForce Go 6200 [DEV_0166] NVIDIA GeForce Go 6400 [DEV_0167] NVIDIA GeForce Go 6200 [DEV_0168] NVIDIA GeForce Go 6400 [DEV_01D4] NVIDIA GeForce Go 7350 [DEV_01D6] NVIDIA GeForce Go 7200 [DEV_01D7] NVIDIA GeForce Go 7300 [DEV_01D8&SUBSYS_81E6104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_81EF104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_81FD104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_8205104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_820F104D] NVIDIA GeForce Go 7400 [DEV_01D8] NVIDIA GeForce Go 7400 [DEV_01DA] NVIDIA Quadro NVS 110M [DEV_01DB] NVIDIA Quadro NVS 120M [DEV_01DC] NVIDIA Quadro FX 350M [DEV_0244] NVIDIA GeForce Go 6150 [DEV_0247] NVIDIA GeForce Go 6100 [DEV_0297] NVIDIA GeForce Go 7950 GTX [DEV_0298] NVIDIA GeForce Go 7900 GS [DEV_0299&SUBSYS_309F103C] NVIDIA Quadro NVS 510M [DEV_0299] NVIDIA GeForce Go 7900 GTX [DEV_029A] NVIDIA Quadro FX 2500M [DEV_029B&SUBSYS_309F103C] NVIDIA Quadro FX 1500M [DEV_029B] NVIDIA Quadro FX 1500M [DEV_029D] NVIDIA Quadro FX 3500 [DEV_0397] NVIDIA GeForce Go 7700 [DEV_0398&SUBSYS_81EF104D] NVIDIA GeForce Go 7600 [DEV_0398&SUBSYS_81FD104D] NVIDIA GeForce Go 7600 [DEV_0398&SUBSYS_8205104D] NVIDIA GeForce Go 7600 [DEV_0398] NVIDIA GeForce Go 7600 [DEV_0399&SUBSYS_81FD104D] NVIDIA GeForce Go 7600 GT [DEV_0399&SUBSYS_8205104D] NVIDIA GeForce Go 7600 GT [DEV_0399] NVIDIA GeForce Go 7600 GT [DEV_039A] NVIDIA Quadro NVS 300M [DEV_039B] NVIDIA GeForce Go 7900 SE [DEV_0407&SUBSYS_01F11028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_01F21028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_02281028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_02291028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_022E1028] NVIDIA GeForce 8600M GT [DEV_0407] NVIDIA GeForce 8600M GT [DEV_0408] NVIDIA GeForce 8600M GTS [DEV_0409&SUBSYS_019B1028] NVIDIA GeForce 8700M GT [DEV_0409&SUBSYS_019C1028] NVIDIA GeForce 8700M GT [DEV_0409] NVIDIA GeForce 8700M GT [DEV_040B&SUBSYS_30C3103C] NVIDIA Quadro NVS 320M [DEV_040B] NVIDIA Quadro NVS 320M [DEV_040C&SUBSYS_20D917AA] NVIDIA Quadro FX 570M [DEV_040C&SUBSYS_30C5103C] NVIDIA Quadro FX 570M [DEV_040C] NVIDIA Quadro FX 570M [DEV_040D&SUBSYS_019B1028] NVIDIA Quadro FX 1600M [DEV_040D&SUBSYS_30C3103C] NVIDIA Quadro FX 1600M [DEV_040D] NVIDIA Quadro FX 1600M [DEV_0425] NVIDIA GeForce 8600M GS [DEV_0426] NVIDIA GeForce 8400M GT [DEV_0427&SUBSYS_01F11028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_01F21028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_01F31028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02091028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02271028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02281028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02291028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_022E1028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_9008104D] NVIDIA GeForce 8400M GS [DEV_0427] NVIDIA GeForce 8400M GS [DEV_0428&SUBSYS_9008104D] NVIDIA GeForce 8400M G [DEV_0428] NVIDIA GeForce 8400M G [DEV_0429&SUBSYS_01FE1028] NVIDIA Quadro NVS 140M [DEV_0429&SUBSYS_20D817AA] NVIDIA Quadro NVS 140M [DEV_0429] NVIDIA Quadro NVS 140M [DEV_042A] NVIDIA Quadro NVS 130M [DEV_042B&SUBSYS_01F91028] NVIDIA Quadro NVS 135M [DEV_042B&SUBSYS_01FE1028] NVIDIA Quadro NVS 135M [DEV_042B] NVIDIA Quadro NVS 135M [DEV_042D&SUBSYS_01FF1028] NVIDIA Quadro FX 360M [DEV_042D&SUBSYS_024A1028] NVIDIA Quadro FX 360M [DEV_042D&SUBSYS_024B1028] NVIDIA Quadro FX 360M [DEV_042D] NVIDIA Quadro FX 360M [DEV_0530] NVIDIA GeForce 7190M / nForce 650M [DEV_0531] NVIDIA GeForce 7150M / nForce 630M [DEV_0532] NVIDIA MCP67M [DEV_0533] NVIDIA GeForce 7000M / nForce 610M [DEV_053F] NVIDIA MCP67M
Sep 12, 2008 | Computers & Internet
Graphics Card Driver Trouble
did you try to update driver from device manager or uninstall drivers from there this could be where problem lies as device manager removes all parts of driver other programs may not remove all parts even though they say so
Jul 04, 2008 | Evga e-GeForce 7900 GT CO SUPERCLOCKED ,...
Computers & Internet Logo
David Payne
David Payne
