Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP 6110 officejet all-in-one
Error message "remove and check cartridge
  • 5 more comments
  • nana12965 Sep 25, 2008
    it say remove right cartridge not right i take it out and put it back doesnt help is holding meomery of error dont know how to fix
  • Anonymous Oct 23, 2008
    Same problem, I have replaced bith sartridges but still cannot remove the error????
  • Anonymous Oct 31, 2008
    Same thing
  • Anonymous Feb 18, 2009
    Sam problem for me
  • Anonymous Feb 26, 2009
    error displays open door clear cartridge jam
  • sfda410
    sfda410 May 11, 2010
    Fiend your solution direct from hp. Here is your solution...
    http://www.hp.com/printer/prob676ijt65/s...
    22
  • nana12965 May 11, 2010
    some one told me that i need to remove the battery cause its holding in memory that there is a problem with cartrige mine are in slots and are full i dont know how to open it enough to get to battiers they say if i take it out for 2 to 3 minutes the put back should solve problem
I am having this problem as well. What do I do?
Posted on Sep 29, 2008
Where can i find the ink level
Posted on Sep 26, 2008
    Scholar:
  • 65 Answers
It could be that the ink cartridge of the printer is not properly connected. Make sure that the ink cartridge is seated properly on its slot. Also make sure that the ink cartridge is full.
Posted on Sep 10, 2008
4 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: Remove and check cartridge
I suggest that the inkjet ports on the ink cartridge, and perhaps on the printer, are clogged with dried ink. The ports I'm speaking of are tiny, minuscule holes, in the ink cartridge. Ink comes out of the cartridge, and through these tiny holes. The size we're talking here, is almost microscopic!
On the printer itself, there are holes that match. Match the holes for the ink cartridge. These become clogged also.
I would like to suggest this. Works for me, printers in my shop, and to many, many people I've suggested it to. (I will repair basic problems on a printer. The computer itself is my forte)
Printer UNPLUGGED from electricity. Open the printer body, remove the ink cartridge. If there is more than one ink cartridge, you may want to remove them as well. Give yourself room to work.
(This isn't really like work. You'll see what I mean)
Use a clean, lint free, cloth. Soak it in very warm water. Actually as warm as you can stand to the touch. Wring the cloth out until it is just damp. No drips of water are present. I suggest you don a pair of rubber dishwashing gloves. Keep any ink from getting on your hands, or wrists.
On the front of the ink cartridge you should see a brass strip of metal, or brass contact pads. If the cartridge has the brass metal strip, the holes are probably in it. If it has the brass pads, the holes are probably nearby. Wipe the area the holes are in. If there is no obvious area that looks like where these holes would be, wipe the entire area that contacts the printer.
As you wipe, you should pick up some ink. I suggest you use a fresh area of the cloth, and continue. When you are satisfied the ink cartridge holes are clean, set the cartridge aside.
Now with a clean, fresh surface, wipe the area on the printer where the ink cartridge meets.
You may want to follow up with a clean, lint free dry cloth on the ink cartridge. It needs to be dry before reinstalling.
You may want to use a hair dryer set on low heat, to speed up the process of drying the printer out.
Keep the hair dryer constantly moving, and about a finger length away as you use it.
I Do Not suggest the hair dryer trick for the ink cartridge.
When you feel satisfied that everything is dry, reinstall the ink catrtridge. Close the printer, and make sure it's down tight. Plug the printer back into electricity. Turn the printer on. Go to the Diagnostic Tools section, and run diagnostics.
Do the alignment test, and print pattern test.
In your Help section, it will show you where the diagnostic tools are, and how to do the alignment test.
Posted on Apr 16, 2009
  • 1751 Answers
SOURCE: my hp officejet 6110 says remove and check
Hi
try reinstall your cartridges if it still says the same error
you need to replace them the one or and the both cartridges
If I help you pls vote me
Posted on Nov 01, 2010
  • 7 Answers
SOURCE: HP Officejet 5510 error "Remove & check color cartridge
Re: OfficeJet 6310 Tricolor (93/95) Cartridge Stops Working After Replacing B/W (92) CartridgeOptions
04-26-201210:27 PM
1. Remove all cartridges and turn off printer
2. Unplug printer and wait one minute
3. hold down # and 9 while plugging power cord back in.
4. Wait a few seconds, then press the power button.
5. Display should read "Full Null Reset"
6 Only install color cartridge. Close cover
7. Wait for machine to ask for black cartridge, then open cover and install black cartridge.
8. Close cover
9. Alignment page should be printed automatically.
Posted on Apr 27, 2012
HP 6110 Officejet printer has error message "Check cartridges/missing
are you using refill cartridge, replace the problem cartridge and check for the results, if you are still getting the message then the issue is with the printer hardware, contact the manufacturer for options.
May 26, 2014 | HP OfficeJet 6110 All-In-One InkJet...
My hp officejet is displaying a message "remove
Your printer is in Error mode.. Specially with black ink empty message. HP Printer is designed in such manner that it will not allow you do to anything if it gives cartridge error message on printer screen.
you will have to replace the cartridge and align the printer to get it working.
Regards,
Ron
Jun 12, 2011 | HP OfficeJet 6110 All-In-One InkJet...
My hp 6110 has a flashing exclamation mark and says "Remove and check cartridge". I have removed and replaced both cartridges several times but the light stays on and the message still appears. HELP!
Hi
remove cartridges
get a peper towel
and clean metal contacts of cartridges
and the metal contact of cartridge carrier
if the error insist
you need to replace with new ones
If i helped you pls vote me
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Cant print and im getting an error message
This generally means that the cartridge is empty or defective and needs to be replaced with a new one.
Sep 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Apr 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Replace all ink cartridges at the same time.
Jan 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110
http://www.hp.com/printer/prob676ijt65/solution
a20
Dec 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
"remove and check cartridge" error message
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02180&cc=in&lc=en&dlc=en
I resolved the "remove and check cartridge" issue after reading the instructions at the above address. Most importantly, I replaced both cartridges and the problem was resolved.
The color cartridge appeared to be the issue. It had been in for months and used infrequently.
May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Remove & Check Cartridge message
Hi Scallag,
Please check with the ink cartridge numbers given below.
HP Officejet 6100 series All-in-One model Black cartridge Color cartridge Photo cartridge HP Officejet 6110, HP Officejet 6110xi, HP Officejet 6110v HP 56 HP 57 HP 58
Click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01299067&cc=us&lc=en&dlc=en&product=79477
Here is the other web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01300415&cc=us&lc=en&dlc=en&product=79477
Have a great day!
Mar 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
450 people viewed this question
Ben Johnson
