Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Picture Distortion 2002 KP-53HS30. Fills the entire screen with picture, but from about 1/3 out from center the picture separates into red, blue and green repeats. The volume bars across the bottom bow toward the middle as well as any information across the top of the picture also bows toward the middle. Any information panel from sat TV looks like a sideways hour glass.
  • Ralph Babcock Apr 03, 2006
    Where do I get the schematics for this?
    President:
  • 3,130 Answers
You have a convergence problem.. If you understand how this works then you can go into the set find the convergence ic's and replace them and sometimes you need to do some alighnment as well. Its always best though to let a service tech do a job like this as he will have all the proper equipment to adjust and troubleshoot the set Good luck
Posted on Mar 31, 2006
Need a remote for
Most older Sony remotes will work on the model indicated here---convergence or picture looks somewhat 3d?
Jun 14, 2012 | Sony KP-53HS30 53" Rear Projection...
Picture is concave and red, blue, green rainbow shadows objects on the screen.
This is and indication of convergence chip failure. two stk-392-560(ic's 8002,8001) and their assocated bell fuses. Our shop generally charge around 150 for this repair. But prices vary with shop.
May 25, 2011 | Sony KP-53HS30 53" Rear Projection...
Double images red blue green lines
My picture screen has double images red,blue,green. The screen looks 3D
Dec 28, 2009 | Sony KP-53HS30 53" Rear Projection...
My picture is red
if you are using component cables, make sure all are plugged in on both the back of the tv and the cable box. (component cables will have a red and white audio and red, blue, green video)
Oct 19, 2009 | Sony KP-53HS30 53" Rear Projection...
My Sony KP-53HS30 rear projection tv looks like a 3d movie without the glasses. It comes and goes and sometimes will have red, green, blue squigley lines all over the picture
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 started with Pink and Blue picture and timer blink
You probably have one or more bad CRT's causing the problem. Due to the age of the set and cost of repair, I would not invest the money needed to repair the set properly. I would replace all three CRT's and the cost would run over 1000.00 up to 1300.00 .
With the cost of new sets today, you could replace it.
I hope this helps,
Skyassoc
Aug 05, 2009 | Sony KP-53HS30 53" Rear Projection...
Color distortion and arched picture
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Oct 31, 2008 | Sony KP-51WS510 51" Rear Projection...
The picture is out of foucus
If your tv is Sony KP-51WS500, then its rear projection tv and problem seems in convergence stage.
Please confirm model number to guide you further.
Oct 11, 2008 | Sony KP-51WS500 51" Rear Projection...
It is problem of failure of convergence ICs or related circuit. Please confirm model number of your TV that is Sony KP-57WS500 to help you out.
It would be nice if you could past TV snap shot here for easy understanding.
Thank you.
Oct 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony projection tv kp-53hs30 made nov.2003
do you think you can take a picture and send it to this website
Aug 08, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
137 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
