posted by rangie on Mar 30, 2006
The lens on my Fuji S5500 camera seems to be lose when extended, slight movement when I hold end and gently move up down or sideways. Also slight rattle when gently shaken. Pictures seem ok but I cannot be sure. Display in viewfinder will move as I move lens up or down. Can this be repaired ?
Thanks, Rangie.
Best Solution
posted on Apr 03, 2006
It seems clear to me (and probobly to you as well) that the solution is to tighten up the lens. regarding the question if you can do it by yourself, i think the answer is probobly no. on one hand, there's a chance it is a very simple problem that only requires tighting a screw, however, i wouldnt risk a 500$ camera for a 30$ repair.
my advice will be the local repair shop, if price is too heavy for you, and camera functions fine as it is, you can live with it for a while, just keep in mind it can get worse.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Fuji Fujifilm WL-FX9B 0.79x Wide
Email this problem
Email this problem
This Problem Also Relates To:
APC (NBAC0218) Lens Converter
Sony 0.7x Wide-End Conversion Lens
Sony 100mm f/2.8 Lens
Sony 11-18mm f/4.5-f/5.6 Super Wide-Angle Zoom Lens for Select SLR Cameras
Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Canon EF 400mm f/4.0 USM Lens
Canon EF 55-200mm f/4.5-5.6 II USM Lens
Can you Help with these Camera Lenses problems?
Fuji Fujifilm WL-FX9B 0.79x Wide Conversion...
fujifilm camera
fujifilm camera
i cant get my video to upload... Answer This...
my camera wont work
my camera wont work
The lens will not retract, the... Answer This...
Lens will not retract, shutter...
Fujufilm FinePix E510 digital.... Answer This...
FujiFilm Finepix S5600 - Lens...
everytime i try to take a photo... Answer This...
how to upload pics from my...
i have a fujifilm, finepix a200... Answer This...
Repair Service
Find Camera Lense Repairman Near You:
