Question about Danby Refrigerators
DCW1024WEY Clicking on and off. recently discovered to be defrosting.
    President:
  • 1,462 Answers
Clicking is probably the start relay for the compressor. take cover off compressor electrics and relay will be in view. worthwhile replacing the relay but this fault can indicate a compressor fault
Posted on Sep 10, 2008
Cant get heat to come out of the defrost vents when i push the defrost button. but blows out of the dash vents
Blend door motors are very common on these models, but if someone dropped a pen or something into the defroster duct recently it could jam the door.
Do you hear a clicking when it hit the button? if not, blend door motor, if so.... might still be.
Feb 01, 2013 | 2002- 2004 GMC DURAMAX DIESEL HOT...
We have a whirlpool et1rhmxkq03. I have replaced defrost timer and thermostat. Defrost timer seems to stall and freezer thaws and the compressor stops running. I tap the control housing in the refr
The problem is with the "thermostat" right next to the defrost timer. When you tap on the control, you are actually tweaking the thermostat and not the defrost timer. Here is the thermostat to order.
Here is a diagram of the control box. The thermostat is number 13 and the defrost time is number 4.
Nov 11, 2012 | Refrigerators
02 envoy - "A/C on" indicator (front defrost) causes power loss.
the a/c will always turn on with defrost so the hot air wont crack a cold windshield.it sounds like altenator not keeping up. have it tested.if the engine realy boogs down with the a/c turned on the a/c compressor might be bad.(locking up)
Dec 29, 2008 | 2002 GMC Envoy
Jeep Liberty Defroster does not work when Idle
If you smell coolant, there probably is a leak somewhere.
Mar 11, 2017 | 2003 Jeep Liberty
Air conditioner
this is the way the car is designed when the defrost is on it runs the are threw the evaporator with the AC on . this dries out the air to help defog or defrost your windshield. american cars have been doing this since the 80's . the original idea was to work the compressor in the winter. a AC system sitting not being used has more repairs than one that is used all the time.
i hope this helps
Aug 24, 2008 | 2003 Mitsubishi Galant
Frost in "frost-free" freezer
Hi, This is my suggestion to check the defrost timer. "I would suspect the defrost timer. Remove everything and place in coolers or another refrigerator. Unplug the refrigerator. With doors open let it sit for aprox 6 hrs. A fan blowing into the freezer section will help. Plug back in and see if it works good again. If it works good for a couple of days and problem returns, Replace the defrost timer." Sound like you have already done my little test so the defrost timer needs replaced. NOTE: Refrigerators are well insulated and it takes several hours to completely defrost one so you may want to try it again. Also, I believe the clicking you hear is the fan blade hitting ice. Hope this helps. Let me know. kstfas
Sep 24, 2007 | Whirlpool ET9FHTXMQ Top Freezer...
Refrigerators Logo
97 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
