Toshiba Satellite C655S5195 Logo
Posted on Aug 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, My Toshiba C655-S5195 laptop has worked fine for the past 6 months and just over previous weekend the laptop was not powering up. Even with a new power supply and so, please advise. Thanks. V/R, Ryan
brian soufane
Level 3:
President:
  • Master 693 Answers
  • Posted on Aug 30, 2011
brian soufane
Master
Level 3:
President:
Answers
693
Questions
Helped
511821
Points
4903
You have a motherboard failure...and will need to replace your motherboard. Sorry to be the bearer of bad news.
I have a Toshiba laptop model# C655-S5501 with a bad keyboard (Gator Aid!). I can't find an exact model # match through Amazon. Will the "Eathtek NEW Keyboard For TOSHIBA SATELLITE C655-S5128 C655
Check eBay. I've been working on computers for years and order ALL of my replacement keyboards through eBay. I just found 9 of them after entering your model number; about $16 with free shipping. Sarawill82 hit the nail on the head for the replacement; you tube is your friend if you're doing it yourself. If it doesn't have your exact laptop, look at other videos. It will give you an idea what you need to look for to replace the keyboard.
It beats paying a computer store a $45+ bench fee, and it will only take you about 15 minutes as a novice.
Don't try to clean it; you could cause more extensive damage than just replacing the keyboard.
Power port not working on toshiba c655
You had better replace your laptop charger. Even if you go to repair it, it will cost you the same price of getting a new charger. So it is wise to purchase a new one. Here are two for your reference:
$9.99 for Replacement Toshiba Satellite C655 AC Adapter 65Watt 19V 3.42A
$12.90 for Replacement Toshiba Satellite C655 AC Adapter 75Watt 19V 3.95A
1helpful
Z,/,?,and all four directional keys stopped working on my toshiba satillite c655-5128
The keyboard will more than likely need to be replaced, there are no user servicable parts. Go to www.ebay.com type make and model of laptop, refine search to keyboard.
1helpful
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Fpi need a webcam for my laptop c655 toshiba which one will i buy that will work with it
Hello fpat2479,
The C655 does not have a webcam built into its LCD bezel (case). But there are many webcams that should work on the C655. The TigerDirect.com website offers many webcams in a variety of price ranges. Most of these should work ok on the Toshiba C655:
http://www.tigerdirect.com/applications/category/category_slc.asp?page=2&Nav='c:6911'&Sort=4&Recs=10
If this solution is helpful please click a thumbs-up rating.
Have a great day,
martyshaw152
2answers
Do my laptop have a mic toshiba satellite c655
There are different models of Toshiba Satellite C655 (about 9 models) and some have webcam and microphone built into LCD bezel (like Satellite C655-S5052 or Satellite C655-S5113) and some don't (like Satellite C655-S5068 and Satellite C655-S5049).
2answers
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
