To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Without the remote, you should be able to perform basic tasks, such as:
-change volume level -change progamme -turn the tv on/off -possibly access AV or other inputs
if your tv has a MENU button on it, then you will be able to perform more complex tasks and you may even be able to tune it in etc.
Alternatively, you can purchase a universal remote control that can be programmed to use with your tv.
You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
Press "MENU" on the TV until "SET UP" appears on the screen.
Now press ^ or v until "FAVORITE CH" appears in purple.
Now press < or > to display the favorite channel FAVORITE CH menu.
You will use < or > to got between "SET and "CLEAR."
So now go to "SET" and press ^ or v until you get to channel 1.
If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
