Question about Canon L295 Plain Paper Laser Fax
Line In Use Messege
Dear Sir, My Fax model FAX-L295. Now it showing a messege. that is "Line In Use" . I have check line other side no using. can u help me ? Why showing this messege. I can't send or receive any fax.
  • Jahangir Alom
    Jahangir Alom Sep 11, 2008
    No, Continusly Show             " LINE IN USE"
  • 2,120 Answers
Plug a regular phone into the wall jack. Verify that you have a dial-tone.
Posted on Sep 10, 2008
Sir how do i programme the fax. i have lost the manual.
as per ur model no see manual on Internet
or place paper face downword and dail number
Jul 18, 2011 | Canon L295 Plain Paper Laser Fax
Have an HP Laserjet M1319 Fax Machine. Fax line appears to be working but I can't send or receive faxes. It shows"receive" when they come in, but won't print them up.
Sometimes these machines will give you automatic messege "Recieve."
If this is only plugged in the fax machine, can you hear the machine dialing or hear the machine recieving a dial tone?.
Some machines have the audio sound turned off, so it is quiet when the machine is doing fax transmissions to limit the noise.
If you can turn it on you can make this eaisier to resolve. If it is on then you can make this more simplier.
Make sure the settings are set right, Junk mail turned off, set up the fax answer mode to print, and not store, check to see if the auto confirmation can be turned on. When this mode is turned on for this process at least you can get a print out on the fax copy, some will give an error messege.
If you can put an analog phone into the fax line, use another phone to call that number and see if it rings. This will ensure the phone line is working well.
If this line has a phone line converter, digital to analong, this may cause some of the issues. More and more people are trying to use the internet as their phone line as a fax.
I would like to know if any of this resolved the problem. There are more questions I have to this type of problem.
Good luck.
Oct 16, 2009 | HP Office Equipment & Supplies
My L295 fax machine does not recieve and print
The Fixing unit of the fax is blown.Replace the fixing unit.
Aug 12, 2009 | Canon Office Equipment & Supplies
Sir, can anyone help me with my fax (canon fax l295)for a problem, it was always indicating that "load paper" even though i put paper on the tray once it was start feeding it makes an paper jam error and...
You either have a paper path blockage or your feed rollers are worn. You'll need to take it apart to check though. Try removing paper, turning machine off and on and re-inserting paper. Remember to fan (separate) paper before loading, it could be static causing the sheets to stick together and jam in the machine.
Jun 11, 2009 | Canon L295 Plain Paper Laser Fax
Are one touch dialing board not working
When sending, try using a analog phone, and dial the number you are calling. Make sure it is the correct number. You might hear someone pick up the phone, or you will get a recording messege. This will tell you if the phone is the correct number you are trying to dial. When you are finished, plug in the phone line back into the correct jack on the fax machine.
Once you hear the dial tone, your phone is working.
If you can send a fax, and the machine does not send it, then the machines fax board might not be working.
There are other questions I like to ask about the phone line. Are you using a adaptor to convert the analog signal to digital? If this is the case then the adaptor may be causing some problems with your faxes.
Good luck.
Feb 27, 2009 | Xerox WorkCentre Pro 765 Laser Printer
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
How to connect canon L295
Hi THe main difference in the phone fax line is that if you are only using as a fax plug the cable from phone socket into the line socket sometimes this may be marked line/tel then the hand held phone goes into the tel socket.this should make it a little clearer..line to wall socket ....and tel to hand telephone
May 02, 2008 | Canon L295 Plain Paper Laser Fax
Printer error 054
That's because you need to take out cartridge and put it back! See is there any jamed paper inside!!! Error 054 is about cartridge!! Can't read that cartridge is inside the printer!!!
Feb 07, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Message Indictator
hi its hard to understand... the phone is connected to line 4 or not? if so and line 4 is dedicated to fax line then the fax tone is the cause of your confusion fax tone is different from a regular tone phone if the phone isnt connected to line 4 and only to all 3 ordinary lines - then the phone is getting a over volage from them and activates the light & messege alert my advice let it be you will start playing with it something else will go worng... good day
Feb 19, 2006 | RCA 25414RE3 Corded Phone
Canon L295 Plain Paper Laser Fax Logo
154 people viewed this question
old marine
old marine
