Question about Maytag Neptune MAH5500B Front Load Washer
New maytag washer
Why is my washer maytag doenst wanna fill up water?
and i noticed that everytime i put it in LARGE loAD i smell something burning and its getting warm on the left side of the washer?i just my washer two 3 months ago...
PLS help me
    Sergeant:
  • 409 Answers
since your washer is under warranty, have a tech take a look at it.
sounds like you may have a loose belt.
is there an error message on the display?
Posted on Sep 23, 2008
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
My washer wont spin and it smells like it is burning it is only 3 yrs old
The burning you smell is probably the belt slipping. There is a belt which is attached to pulleys. The belt engages to spin the basin in the washer. When this belt slips the burning smell happens because the pulleys are spinning and the belt isn't. You will probably need to adjust the tension on the pulleys or get a new belt. This can happen from constantly overloading the washer or trying to get the washer to wash and extra large load while the water level is set at a smaller load.
Aug 07, 2010 | Maytag Washing Machines
I HAVE A TOP LOAD MAYTAG WASHER AND WHEN IT GOES
You need to unclog your water pump. Sounds like something big is stuck in there if it's buzzing. Remove both large black water pump hoses and check hoses as well as the pump.
Mar 18, 2010 | Washing Machines
Maytag Neptune MAH5500BWW burn smell (doesn't appear to be hose)
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
Oct 06, 2017 | Maytag Washing Machines
Washer fills with water, loud thump sound, no agitation occurs.
The thump is probably the motor trying to start followed by the burning smell of the belt slipping. See if something is jammed, but the most likely thing there is a bad transmission.
Dec 31, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sorry.........................
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer just stopped
I would check the drainpump ans see if there is something jammed inside like a coin or screw,nail etc before doing anything else .Unplug the machine first though . A burning smell will occur with a load of water trying to spin .
Nov 06, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag Neptune MAH5500B Front Load Washer Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
