it is a possibility that it can't be done that way, after market radios usually have to be wired into the wiring harness they don't just plug in for the simple reason vehicle manufacturers want you to use their radios & equipment NOT after market radios etc , you may have to get a auto radio installer to fit it for you otherwise if you don't know what you are doing it could be more costly in the long run......hope this helps......cheers.
there is little space to unbolt the starter and then wiggle it around to drop it. Unbolting the crossmembers is a real pain, so don't consider unless you can get to the back side of each bolt. So. Get some nut/bolt remover and spray on the bolts and nuts that attach the exhaust pipe to the two header exhaust pipes. Be patient during this and hopefully you won't break a bolt while removing the nuts. Try to tap lightly on the nuts to loosen some. Have a socket wrench with an extension to reach . Or, better yet, have an impact wrench to use. The impact action of the wrench helps to loosen the nuts. Do this removal of both exhaust pipes from the headers. Remove the bolts that hold the starter in place, slide forward a little and drop. But, be sure to note how wires are attached and be sure to remove the positive battery cable from battery before starting. You have to do this from underneath, so support it safely. Can't say I would want to buy a rebuilt starter and have to do it all again. It would be nice to have some extra nuts and bolts on hand, but I don't know the sizes. If you break one. Take it to the parts store. Call the parts store and make sure they have the starter on hand before you start, unless time really doesn't matter on how long it takes to do this job. Take your starter with you to compare and to get a "core charge" counted toward the purchase. 93 roadmaster 5.7L
go to walmart find your cd player, dash kit ,wiring kit and then this is what you do .. remove the old radio attach the wiring harnes you bought to the factory wiring harnes this will allow you to match the color code up for your new radio with out cuting wires then install the new dash kit witch will allow you to install your cd player with a factory look this should be everything ou need to know
