Question about Lands Phones
Unable to call or receive calls
Tje message box displays "phone in use" and when I try to make a call it always indicates "Busy" My family and Freinds say they can't reach me at home. This is a safety risk for me as well.
    Brigadier General:
  • 5,158 Answers
Ok... here is the user manual.
http://service.us.panasonic.com/OPERMANPDF/KXTG3021.PDF
if you cannot read the manual please contact me again and i will give you more detailed instructions.
A quick fix may be to put the handset in the charger for a couple seconds... you will see the light on the base flicker.... pick it up and it may very well be ok to use.
Robert
Posted on Sep 10, 2008
  • Roberta Smith
    Roberta Smith Sep 10, 2008
    Jean... also you may wish to make sure the phone jack is plugged in completely into the base and the wall jack as well.
    Robert
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
Unable to send message in my nokia N71.. how to fix this??
Please try by restoring your factory. Menu>Setting>Restore factory setting. or press this code *#7780# and if you want to format it than try this code *#7370#
else please check your message center number from your friend or family that they are using the same service(s) like vodafone, aircel, bsnl, airtel. from there check their message centre number whether it's the same number or not that's in your cell-phone. If it's not same than correct it and try.
Thanks for using FixYa
Sep 15, 2012 | Nokia N71 Cellular Phone
Unable to make/recieve calls get 'network busy' message but can make/recieve texts
Since the network 'shows' busy, it could actually mean that the network is jammed. This may allow text messages, but not calls. The problem is with the network and not your phone.
Contact your mobile service operators to know what the issue is. They could be working on the system. But if they are not, I'm sure would able to restore full network so you can make and receive calls.
Please do let me know if this helps.
Have a lovely day.
Jun 06, 2011 | Nokia Cell Phones
My red message indicator light is on, but i dont have any messages. How do i fix this? Panasonic KX-DT343
Press the MESSAGE button and look at the display. The red message light is lit from any phone pressing the MESSAGE button when they call you or (a Pana whoops) dialing 4 into the busy tone.
One of the soft keys under the display will be CLEAR. That clears the message from that phone.
Carl
Jul 29, 2010 | Panasonic KXDT343 Phone
Message Light
press #409 to cancel message receive
press #64 follow by et\xtn on display to cancel sent message
mayb st 21 been assigned, but no body know.to check, call from all extn to displayed phone.check 1 by 1.
if light keep blinking for mic, try to change other key phone
May 27, 2009 | Toshiba DKT-2010 Corded Phone
I cannot use my phones since Saturday. The phone message on hand
try to perform a soft reset.
Using:
menu/settings/ restore factory settings.
Dec 22, 2008 | Uniden Cordless Phone
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
Feb 13, 2008 | Lands Phones
Lands Phones Logo
127 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
