Question about Mitsubishi WS-55513 55" Rear Projection HDTV
WS-55859 Picture "clicked off to black"...never to be seen again. When I power the TV up, it shuts off within 3-4 seconds...thoughts? Bulb or something more involved? If thoughts are bulb, rough idea of cost and how easy or hard is it to replace on my own?
    Novelist:
    Champion:
  • 203 Answers
The set is going into shutdown most commonly caused by convergence in that model, if you know how to use a meter i can help you check some pico fuses to determine the problem. Otherwise you will need to call a repairman. Let me know if I can help
Tim
Posted on Sep 11, 2008
Ws 55859 has audio but picture is black
This unit does not have a lamp, but 3 CRT's. Odds of all three tubes failing at once is very remote. I would look at the voltages that run to your CRT boards and see if they are low or have a load. You should also check your circuit boards on the bottom of set to see if the CRT's have been leaking glycol. If the board looks wet ot corroded, you are dead in the water.
Mar 20, 2013 | Mitsubishi WS-55859 55" Rear Projection...
Push power button and timer button lights for a few seconds and then tv turns off model is Ws 55859
When it shuts down go to the set and press the menu and the Device/Input button both in together and hold for 6 seconds then count the two digit blink code from the power indicator. it will blink a two digit code which repeats several times.
Jul 23, 2011 | Mitsubishi WS-55859 55" Rear Projection...
Tv will not turn on timer button is blinking green
Most common problem is the bulb burns out causing this to occur. The first thing to do is disconnect the power wait about 60 seconds then attempt to turn it on again. If this doesnt work then I would check the bulb. This can be done by removing the cover in the rear you will find a enclosure behind it that includes the bulb. Disconnect it and remove inspect the bulb if its bad it will be noticeable by it being melted black or damaged these can be purchased reasonably online and its a simple procedure. Let me know if there is anything else I can do to help. Thanks for using Fixya
James
Dec 07, 2010 | Mitsubishi WS-55859 55" Rear Projection...
My mitsubishi TV ws-55859 does not turn on. The green timer light comes on and goes off after 3-4 seconds but tv does not turn on. What could be the problem? Help please......
Poor solder connection and Bad STK ICs 2 of them replace Both Big Black IC will have part number on them Call Mats for STK 1-800-628-1118 example
STK392-570.
Nov 18, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Tv does not stay on
If you have a rear projection, it is the bulb. Ypou need to replace it.
Jul 24, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi HDTV 1080 WS-55859. Error Code 12
Did you push in the device and the menu buttons at the same time and get the error code...  I have the same problem and I get a 1,2 code....   I am looking for what the codes stand for...
Have you got any help on this....
Scott
mu email is smartin38@verizon.net
Sep 11, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Blinking green light will not power up
My WS-55859, Did the same thing. Power went out, when it came back on the green light in front of TV would blink, but TV would not power on. Did some googling and saw multiple posts for "blinking Green light" or "Blinking Green light of death". Most of the posts pointed to replacing capacitors on DM Power board. I followed the direction and it worked great. Note the TV shop guy who did the soldering for me said the capacitors "looked fine" and they were not the problem. I couldn't tell the difference between a good or bad capacitor, so I asked him to swap them anyway. He did, I plugged the board back in, buttoned up the back of the TV. After 60 seconds Green light stopped and I started watching TV again... Here is the link to the best instructions I found (http://hdtvoice.com/voice/showthread.php?t=32186).
Aug 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
WS-55859 Won't Turn On
this is a job for experienced tech most of the problems are rela ted to convergence IC's in this case
Mar 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
