Question about Panasonic PT-47WX51 47" Rear Projection Television
Burn marks in screen on my 47 inch pt- 47wx51ce
My screen has a two burn marks in the top middle area of the screen. is there any way to repair this problem. new bulbs ect.???
  • winn500 Sep 10, 2008
    the marks are two small lines which start at the top of the tv screen and go down towards the center of the screen. they are about three maybey four inches long and one is shorter than the other, but they are side by side.
  • fenderbass May 10, 2009
    Similar problem on a Sony KP-53V75. Lines in base of Red lens. Opened up lens and liquid spilled out. What is the liquid and how do I find refill liquid??
    Champion:
  • 230 Answers
Hi, thank you for visit fix ya.
Can you provide me model number tv, please?.
Thank you
Posted on Jul 26, 2009
My 96 cadillac deville's cluster will not work.the fuses are good,its only the middle where the mileage and fuel lights are.
There is a backlight bulb that is burned. You will have to remove the cluster and replace the bulb in the middle. I can't remember the exact bulb number but the old one should have a marking on it. I would suggest replacing ALL the bulbs (I think there are 3 or 4) as long as you have the dash out. They will all burn out shortly due to the age of the vehicle. Bulbs are good for about 10,000 hours or so.
Good Luck.
May 05, 2011 | Cadillac DeVille Cars & Trucks
3 round dots on screen yellow red blue
I have to be honest with you, I suspect the marks are burns on the three picture tubes and permanent.
A simple way to prove this that requires no technical knowledge:
Remove the back cover and locate the three large lens (red, green and blue tubes) and with the set on cover each lens one at a time; if a mark vanishes that tube is burnt in the middle.
If you have three dots or tear shaped marks the set arced and burnt a small area of each picture tube's screen.
These tubes are about 4x5 inches at the screen and are like a regular tv screen; there is a phospher coating and if the set arcs it will burn the coating away in the middle of the screen on each tube.
Confirm this and if true two things would have to happen: replace all three tubes (not worthwhile) and find what caused the arc.
I do not like to give people bad news but I am honest and if this input helped or informed you give this solution a "very helpful" rating as I do this here for free.
If you have ANY questions or need advice do not hesitate to post a comment here and I will respond.
REGARDS, SD TECH
Aug 10, 2010 | Sony KP-53V75 53" Rear Projection...
My projection is in Black and White
I have seen this with a number of X1's and yes it will need to go into service and knowing what the cost of repairs was and the age of the x1 i would start looking for a new projector.
Jun 04, 2010 | InFocus X1 Multimedia Projector
Rca scenium 52" has light bar area down each side
I take it that you have watched many hours of 4x3 video on this 16x9 TV . What you see is evidence of screen burn, like they used to warn about with the old "pong" type games with stationary objects. The 4x3 pattern is burned into the phosphor in the projection tubes. the area of the burned pattern is not as efficient as the unused areas that make up the 16x9. If you watch enough 16x9 it may even out somewhat, but will never be perfect. Replacing the tubes will fix it, but they're pricey, and you may be subject to it happening again, depending on your viewing habits.
May 25, 2009 | RCA Scenium M50WH187 50" HDTV
Stained / darkened image area on about 1/3 of screen
first how old is the tv with your first and second generation flat screens and plasma tvs alot of the logos have burned into the bottom corners of the screen and after awhile they burn so much in it grows to bigger portion of the screen and unfortuneatly there is nothing you can really do for this until its time to buy a new bulb if lcd for the tv sorry
May 14, 2009 | Westinghouse LVM-37w3 Television
Burned out brake light (middle top light)
Take a putty knife and slide it under the front of the cover to release it from the area behind the back seat and pull it forward. Then twist the bulb holder out of the cover. The bulb pulls out of the holder . Replace bulb and reassemble.
Feb 18, 2009 | 2002 Toyota Avalon
How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Nov 08, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Red color trouble
A picture or blank raster viewed from the front will have red marks if a portion of the image path from the green CRT to the front screen is blocked by debris or if the Green CRT is damaged from burn-in or other situations. If green is missing, red dominates virtually any image.
Severe CRT burn-in can occur when there is no sweep signal to a yoke. I have seen technicians removing yoke connectors on RPTVs in attempts to find shorted or suspect components.
Occasionally a damaged TV is sent back to customers as repaired and a service order for a new "fault or complaint" is initiated when the customer complains of the red or green marks or lines.
easyab
Jul 25, 2008 | JVC AV-56WP74 56" Rear Projection...
PSP does not charge.
might be the motherboard or charging board overheating crack open the case if its not under waranty and check all connections . turn the psp on and see if any thing gets really hot really fast or if there are any burn marks also make note that the psp might not freeze up when open ... if this is the cast its a cooling issue.... please be forewarned that opening your psp WILL VOID your warranty and could be hazardous (shock, burn damage ect ect) and that YOU AND ONLY you are responsible for your actions
let me know if this helps :)
May 27, 2008 | Sony PlayStation Portable (PSP) Console
Red spot in the middle of the screen
You most likely have a burn in on the surface of one of the picture tubes. What you need to do to confirm this, would be to take off the front screen, and with the set turned on, look directly into each one of the lenses, and see if you see a mark on the green or the blue tube. if this is the case, and I am pretty sure it is, the picture tube will need to be replaced, but this set is not a young thing, as the green faint lines is most likely a bad capacitor in the screen drive circuit. If the picture tube is indeed burned on the surface, most likely be better off buying a new TV set. Good Luck
Jun 25, 2007 | Toshiba 42H83 42" Rear Projection...
Panasonic PT-47WX51 47" Rear Projection Television Logo
274 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
