Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi VS-5071 rear projection turns on, has audio but no video
I have aa Mitsubishi VS-5071 50 inch rear projection TV and the video just stopped working. None of the projectors light up but sound is great. I examined the PCB's and found no burnt marks and there is no smell of burnt components. The fuses look ok. There is a faint sound coming from the ( coil ? ) on the anode PCB side. Sort of a faint electrical arc ???
  • 2 more comments
  • Michael Fain
    Michael Fain Sep 10, 2008
    Located possible fault with your help. IC401 was loose on the heatsink, C402 was ok, could not locate R510 but found possible burnt out IC circuit and bad connection to the PCB while in the location where R510 should have been near which has the only 2 watt resistor R508 2.7 ohms which might be a circuit mod.
  • Michael Fain
    Bill, Who and where is PTS so I can contact them. Thanks, Mike
  • almckin5 Apr 15, 2009
    everybody that bought mitsubishi big screens has the same or similar problem.
  • saintcyr May 25, 2009
    We have this same problem but with a twist... The video goes out but the sound is still on and clear. I turned off the TV for a week or so and turn it back on and it works. BUT it only works for a week or so. Its been working for a week now with out any major problems. Does any one have a clue?
    Larry
  • 934 Answers
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Posted on Sep 10, 2008
  • William Rayburn
    William Rayburn Sep 10, 2008
    Might want to take it in to a good qualified shop for the repairs, or even remove the board entirely and send it to PTS for rebuilding.
    Bill
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
I have lines like vertical hold is off but can't find ajustment
Thank you to "TheScreenGuy". He replied with an answer that says the vertical sync is automatic and that I need to replace the SSB. Thanks!!!
Mar 23, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 50 inch projection tv
you probably have a problem with the convergence board.
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Video
What kind of input are you using
Nov 05, 2017 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs 50707 50 inch projection tv problem
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Dec 15, 2007 | Mitsubishi VS-50707 50" Rear Projection...
VS 50607 50 inch
Deflection Protect is the problem. You can check C411 and C412 on main board to see if bad. More info ctechnicians.com
Nov 17, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Televison & Video Logo
728 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
