Question about Pioneer DEH-1700 CD Player
DEH -1700 Pioneer
Has worked fine up till now. No response from any of the controls. Can'teject CD, volume no response, can't even shut it off. Have taken the face plate on and off till I am blue in the face. Pulled the power plug and pluged back in, still the same. Any ideas?
    President:
  • 624 Answers
It sounds like you may have a cracked display board. Have you dropped the face plate or has anything hit it while driving? If this is the case, you will need to take it in for repair, but since it is a low cost radio it may not be worth spending that kind of money on it. If the display board is not cracked, it could be the microprocessor or another electronic device. It does not sound like the type of repair that would be able to be done without having a technician check it out. As with most types of problems with electronic equipment, the cause of the problem can be a variety of different things that can only be determined with certainty by troubleshooting by a technician. Since you have no control functions from the display, the most common cause of this I have seen is the board being cracked. It only takes a very small crack in just the right place to render it inoperative.
I am sorry to give you such bad news, if I thought that it was something simple I would tell you. But this is not a simple problem that can be solved without checking it out on a repair bench with the proper test equipment.
If you can find a service center that offers free estimates it would be worth getting it checked out, but if I were you, I would buy a new one and then you would at least have the 1 year manufacturers warranty for about the same price or maybe even cheaper than getting it repaired.
Another option for you could be to contact Pioneer customer service and see if they may cover it for you if your warranty has already expired.
I hope this helped, let me know if I can be of any further help.
Dave
Posted on Sep 10, 2008
Will the Pioneer DEH-17 fit (and work) in a 93 honda civic?
with the proper accessories, it should work just fine.
Oct 14, 2010 | Pioneer DEH-1700 CD Player
Cannot change the time
Push and hold source button till radio shuts off, then push and hold the volume/menu (big round button) till the menu comes up and scroll to clock
Apr 04, 2010 | Pioneer DEH-3900MP CD Player
Replacement volume control knob for pioneer deh
an authorized service centre in the back of the pamphlet that came with the reciever,or direct from pioneer.
Jan 13, 2010 | Pioneer DEH-P6900UB CD Player
Installation wiring diagram for pioneer deh 1700
here is the link for the installation manual and user manual:
http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/CD-Players/ci.DEH-1700.Support
see the installation manual page 1 far right side for wiring diagram is listed as other manual
Cheers!
Nov 17, 2009 | Pioneer DEH-1700 CD Player
How do you adjust the time?
I have been told...
press the source button,
press the audio button till the clock display turns on,
press the arrows till you get the # you want to change,
press the + / - to get the # you want,
press the band button to turn off the clock setting.
This is what I have been told to do to fix the time on a Pioneer DEH 1700
Oct 31, 2009 | Pioneer DEH-1700 CD Player
Pioneer DEH - 1700
The wires that you are looking for on the back of the radio is the yellow, red, and black. The yellow is for constant power, the red is for power only when the key is turned on, and the black is ground. You need all three in order for it to work.
Oct 23, 2009 | Pioneer DEH-1700 CD Player
Preset memory not working on pioneer DEH 1700 radio
You must connect the constant hot wire (or there is a fuse blown somewhere).... it should either be orange or yellow at the rear of the pioneer radio ... it should be connected to a wire that recieves power even when the key is off ... that wire will depend on the car itself ... if you used a connector to plug into the factory wires (a good idea) that connecter should have a yellow wire that would supply a constant "hot" for your pioneer, if it doesn't there should be a fuse blown in the car fuse box.
Apr 06, 2009 | Pioneer DEH-1700 CD Player
AUX input on Pioneer DEH P31000
There is a plug on the back called an IP-BUS. You should be able to hook the ipod directly up to that with a simple homemade adapter. I built one for mine and it works fine.
http://stereophonik.com/gutterslide/IP-BUS_Hack/
Oct 07, 2008 | Pioneer DEH-P3100 CD Player
DEH 245 Lights
Try Turning the Power off holding down the clock button till the clock display flashes then use the volume and tuner keys to set the time.
Dec 17, 2007 | Pioneer DEH-245 CD Changer
Pioneer DEH-1700 CD Player Logo
134 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
