Question about HP Office Equipment & Supplies
Dear Sir/Madam I own an HP Officejet 6200 series all-in-one:printout copies are covered by vertical lines how can this be corrected? Thank you, Yvonne Herman
TeK Micro
  • 62 Answers
SOURCE: How to receive fax on Hp officejet 6200 series
First you should use the manual and follow the fax setup section. These directions will have you click a few buttons on the printer so that the printer knows how to answer the incoming calls.
There is usually a button on the printer named "auto answer" or something similar. If you are using the same phone line to make phone calls then you should turn this button on only when you want the printer to answer the next incoming call.
Also make sure you have the phone line connected to the correct port on the back of the printer.
Posted on Jan 03, 2008
SOURCE: Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Posted on Nov 15, 2008
myjosh007
  • 530 Answers
SOURCE: Sir/ madam printer is not taking printout from computer
hi im josh in phils. may i help you. friend your problem is quiet serious cause if your printer head is damage thats why it will not execute to give the cartridge command to print the paper with ink. i suggest you replace the printer head.good luck
Posted on Feb 21, 2009
  • 1126 Answers
SOURCE: HP OfficeJet J5780 Vertical Black Line Prints when
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Posted on Sep 07, 2009
Xestrix
  • 51 Answers
SOURCE: I HAVE WINDOW VISTA AND IT WILL NOT LET ME INSTALL
You may need to obtain the proper drivers for you printer. Your drivers are available from the HP support website, found here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=391212&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=391210
Simply select your operating system and download the appropriate drivers.
Posted on Oct 26, 2009
Officejet pro x476dw vertical lines after print
Run the "clean inkjets" routine followed by test pages until printout appears correct. Maybe the print cartridges are defective.
Aug 06, 2014 | HP Officejet Pro X476dw Wireless...
When I use the feeder either for scanning or copying, the page has a black vertical line . When I make normal copies or print outs it is fine, only the feeder makes the black line. Thank you
Under the Automatic Document Feeder is a small glass.
This glass becomes dirty, creating lines on the page.
open up the scanner cover and clean the glass
Feb 17, 2011 | HP Officejet 6500 Wireless All-in-One...
My hp officejet 6210 all in one is instaled under general heading: officejet 6200 series. Result: the printer reacts to command given by laptop windows xp but does not print given text. The paper comes out...
Are you able to print Self test page from printer ( standalone ) or able to make a copy ? if you are able to make copy/print self test page from printer, this issue is with Printer Drivers, You can uninstall and reinstall the software ( download the latest software and drivers from HP website )
If you are not able to make copy/print self test page from printer, it is issue with printer/cartridges... you need to re-align the printer
to clean/align cartridge
On Printer Front panel
Press - Setup Button ( press ok)
Press - Tools ( Press Ok )
Press - Clean Cartridges ( Press OK )
And/Or
Press - Align Cartridges ( Press OK )
Jun 22, 2010 | Office Equipment & Supplies
A black vertical line is on each copy.
Try the 6500 driver. I have seen that allow text print but no graphics. If line disappears, reinstall 7680 driver. If line comes back, contact HP about updated drivers, check their website OR try to get your money back. I have never had luck with this series of AIO.
Good luck.
Feb 08, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Sep 07, 2009 | HP Officejet 5780 Printer
HP Officejet J5780 All-in-One
I am going to give you the technical document which you need to follow inorder to resolve your issue. Just click the link below
CLICK HERE==>> SOLUTION ON VERTICAL LINES
Also, i want you to give me feedback on how useful is the document to you.
Thank you so much.
adonscott
HP TECH
Jun 26, 2008 | HP Officejet J5780 All-In-One InkJet...
Copy function
please clean the scan bed glass, rollers and then try to copy it
Mar 13, 2008 | HP Officejet 4110 All-In-One InkJet...
Seeker5211
Seeker5211
