Question about Whirlpool Washing Machines
My sister just brought me an old washer and for the life of me i can't figure out why it won't keep the water in. it pumps in water, but it immediately drains it. i'm almost positive it is set up right. what is wrong?
    President:
  • 1,462 Answers
I suspect you have it wrongly installed on the drain.
if the drain pipe goes into a standpipe, you may have drain pipe pushed too far down and a syphon forms. drain pipe need only go into standpipe a few inches.
otherwise, if not drained into a standpipe, take drain hose up in a swan neck to worktop level
Posted on Sep 10, 2008
Dishwasher won't drain all the way
A dishwasher will never drain all the way. It is designed to hold water as to not let the pump run dry and keeps the seals preserved.
Jun 03, 2017 | GE Nautilus 24" Built-in Dishwasher
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Oct 11, 2012 | Washing Machines
CHANGE DRAIN PUMP WASHER
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
The washer broke filled with water and won't drain
Sep 28, 2012 | Kenmore Washing Machines
GE WSXH208V1WW
Usually when you have a washer that will not drain, first check if the drain hose is kinked or too high above the washer (8 ft is the limit of the washer pump). Next check if there is a blockage in your drain (often a stand pipe) or if the air can't get into the stand pipe. The final thing to check is for foreign objects in the pump to drain hose area that block the drain. (This requires getting into the pump and disconnecting the hose. Keep a bucket ready to catch the water that will pour out of the washer.)
GE has the manuals for many of their appliances on their support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click submit. The direct link to the manual for the WSXH208V1WW is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90256.pdf .
I hope this helps.
(at least my washer won't spin if the water can't pump out. On a few washers (non-high efficiency) the solenoid has failed to open for the pump to drain the water.)
Nov 22, 2011 | Washing Machines
What oil to use in the power washer water pump
Oil used in engine is SAE30, I would suggest adding bit of Nulon or similiar Teflon based before even first run as it will extend life of the engine, This is air cooled Honda and therefore overheat easy.
Oil used in pump is Universal Tractor Transmission Oil.
Except two, all pumps are equiped with sight glass, fill as indicated on sight glass or dipstick.
To extend life of your equipment, change oil in both, engine and pump after 50hrs.
If you live in colder climates, where freezing is possible, do not forget to drain pump and high pressure hose from water to avoid winter damage.
Hope this will help keep your equipment in top notch for years to come:-)
Jun 22, 2010 | Northstar Pressure Washer 3000 PSI
How to get the back off a waher
The back is resting on some slots, try lifting the plate out of these slots.
Jun 28, 2007 | Whirlpool GSW9800PW Washer
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal De
