Re: Curtis Mathis 5000pmk how do
Re: Curtis Mathis 5000pmk how do you sharpin the picture and adjust the color?
Sparky-UK
  • 129 Answers
SOURCE: can not find the code for a curtis mathis brand
Hello, you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 21, 2007
yalmer
  • 549 Answers
SOURCE: adjusting curtis mathes projection tv model fp4600ek02
If this tv is more than 10 years old, I would say the three projection tubes are getting weak.
This may be a good time to invest in a new tv.
considering the difficulty of obtaining parts for it and the other problems you could have in the near future, it would be cheaper to replace the tv.
If the tv is not that old, please let me know the model number for more assistance.
Posted on Jul 02, 2008
  • 133 Answers
SOURCE: What is the code for
I own a One-for-All universal remote, and my booklet says that the setup code for a Curtis Mathes TV ( without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee that these numbers will work with your remote, but it is worth a try.
Posted on Jul 06, 2008
  • 7 Answers
SOURCE: do not know the code,have a curtis mathis tv
You can find the codes at this site.
http://www.oneforall-int.com/
Posted on Sep 07, 2008
SOURCE: lost color on curtis-mathis tv
CHECK FOR AND REDO LOOSE SOLDER JOINTS
Posted on Nov 20, 2008
I am trying to adjust the brightness on this circa 1980 floor model solid state tv
The contrast setting controls the relation between the light and black areas of the screen. If the light areas are too bright and are losing details, press the CVOL button; if the picture is gray and lacks contrast, press the VOLB button
The brightness setting controls the overall amount of light in the picture. If the picture is too bright, press the CVOL button; if the picture is too dark, press the VOL B button
The color setting controls the intensity of color.
Curtis Mathes CM19102 Owner Manual Returning To The Factory Settings...
Apr 09, 2016 | Curtis-Mathis Televison & Video
I can't access the advanced settings on my Curtis-Mathis TV
is it possible to connect my toshiba regza rv75 tv to the internet
Dec 15, 2013 | Curtis-Mathis CM19011 TV
Screeen color is green
This fault is called one color predominant screen. The cause might be to its video output card itself. There will be some loose solder terminals around the Green video output transistor. Check this card for any loose solder terminals. Just re-solder all the suspected solder terminals by applying a little more solder, without making any solder bridge short in between adjacent solder terminals. This card can be located at the neck of the picture tube [a rectangular board], will be directly plugged on to the back of the picture tube.
Dec 27, 2012 | Curtis-Mathis CM27101S TV
Tv_weight, curtis mathis 36 inch tube
Hello
The TV you specifies here [Curtis Mathis 36" picture tube type] has a weight of 150.3 lbs. OK.
Oct 19, 2011 | Televison & Video
Curtis mathis tv takes to for picture to show after turning on
Look for a bad caps 250volt 2.2MF and a 25 volt 47MF near the horizontal deflection! And you may as well check the caps near the vertical IC as these are going bad...you have board out..you may as well do this. Then you will have a reconditoned TV with added years!
Feb 19, 2010 | Curtis-Mathis CM27101S TV
Is a Curtis TV the same as a Curtis Mathis TV
Curtis International Ltd of Etobicoke, Ontario is not Curtis Mathis, famous for building quality TV sets.
Sep 12, 2009 | Televison & Video
Lost color on curtis-mathis tv
Nov 20, 2008 | Curtis-Mathis Televison & Video
Horizontal adjustment.
I have the same problem. Just what is the repair?
Garry Meyer gfm001@aol.com
Jun 30, 2008 | Curtis-Mathis CM27101S TV
Blue picture on tv
Have you tried cleaning the projectors and the reflecter? I have same model and it wont turn on. Email me if you still have this set. Cudajim@cudajim.com
Nov 19, 2007 | Curtis-Mathis Televison & Video
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
