Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Light bulbs I dont have the back lower bulb to know the shape other then its a med base 40w?
  • 126 Answers
MOST FRIDGES COM WITH A SCREW TYPE GOLF BALL SHAPED 40W GLOBE.GOODLUCK.MOHAMED
Posted on Sep 12, 2008
Why will the lights no longer come on, on my ceiling fan, when the fan works fine & everything else is fine? What happened?
you get a slight shock suggests that you have a major wiring problem
at some point the installing electrician has used a ground wire as a neutral wire and there is live feed back that should not be occurring
Get in an accredited professional electrical inspector to run a full scan and test on the house wiring and then go from there
Jan 01, 2018 | Home
?y light is out and I don't know where the light is so I can replace it. I can't find my manual. Model number: GX5FHDXVTOO. WHIRLPOOL FRENCH DOOR
There should be a plastic grille mounted on the ceiling of the fridge, usually, a good tap with the palm of your hand, towards the rear of the fridge will pop the grille loose and expose the light bulbs. Be sure to replace the bulbs with 40w appliance bulbs only! if replacing the bulb doesnt work, you may need a new light switch or the metal tab in the bulb socket may not be contacting the base of the bulb properly...
Apr 25, 2016 | Whirlpool Refrigerators
How to change oven light
Which model Whirlpool range do you have? For most Whirlpool ranges that I have used , the oven light is covered by a screw-on glass cover. When the oven is cool, unplug the range, open the door and turn the cover counter-clockwise (to the left). Then remove the 40W bulb (again counter-clockwise rotation). Replace the bulb with another 40W appliance bulb. Then replace the cover by turning it clockwise until it is tight. Do not over-tighten either the bulb or the cover. Then plug in the power cord for the range. (Unplugging the unit makes sure that you will not get shocked if anything goes wrong. Sometimes the bulb may break in the socket - in that case, use pliers to unscrew the base of the bulb before replacing it with a new bulb.)
Whirlpool has the manuals for most of their appliances on their support site: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
I hope this helps.
Jan 11, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Im trying to change my break light bulb but dont know how to access it
If it is a car, open the trunk. You may have to pull back the carpet lining which will reveal the light bulb connections or access panel. On a truck, drop the tailgate. There should be mounting screws inside the jam (where the tailgate meets with the bed of the truck). Remove those and pull the taillight assembley out carefully. Twist the light bulb connector counterclockwise to remove the lightbulb and connector. Then do the same with the light bulb if it is cylinder shaped at the base. If it is flat then just pull the bulb out ane replace it.
Jul 22, 2011 | Ford Grand C-Max Cars & Trucks
Two different size ultraviolet ballast. The .71AMP ballast feeds two 40W ultraviolet ''UV'' bulbs. The .37AMP ballast feeds one 40W ultraviloet bulb. The two light to larger bal;last want come on. The...
I usually test the ballast simply by excluding everything else.
1) Put in bulb that you know works
2) Replace starter (if you have one)
3) check that wiring is intact (sounds like it is for you but I had one light that the wiring barely made contact so sometimes it came on and sometimes it blinked)
4) If all that is good, then it's probably the ballast.
Sep 29, 2009 | Garden
Cannot find a replacement bulb (Phillips X4J-40 watt)
I had the same problem and found bulbs that fit through elightbulbs.com. You have to look for a European base, 40 Watt, 120 Volt incandescent light bulb. They are about $3.50 each plus shipping. I bought two and they are excellent. I've ordered another 6. They are shorter looking than the original Phillips bulbs, but just as bright and you don't have to replace the sockets. Good luck!
Apr 03, 2009 | TecnoWind 90 cm (approx. 36 in.) Classic...
40w candleabra bulb blew now can't turn lights off with remote
There is a receiver in the fan that when the light blew might have damaged that part of the receiver. I think you can buy them,but you will have to get into the base of the fan(ceiling cover).
Jan 02, 2009 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Light does not come on when I open/close door, not the bulb
Good Morning:
I also substituted Floescent Bulbs for the standard bulbs. The bulbs would not light up although the relay was working. It seemed that the Florescent bulbs had a somewhat shorter neck. What I did was unplug the drive system from the outlet and then bend the metal connector in the socket so that it would come out further towards the opening of the socket. I then repluged the drive. The Floercent bulbs now have contact and are working perfectly. Simple problem with a simple solution.
Sandman
Oct 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Light bulbs
fan may have a lot of vibration. or the MAGNETRON is kicking back a jolt. or your slamming the door too hard.
May 12, 2008 | GE JVM1660 Microwave Oven
Kenmore microwave down-lights not working, model 721.62643200 1000W
This is a very common problem we repair. The main causes are when the filaments short the power supply or when a bulb is removed or installed with the oven plugged in. We repair these control panels for $32.50 nationwide. For more information about our repair service, plus our critical safety and disassembly info, see our listing here on FixYa: http://tinyurl.com/yzjozk
Jan 31, 2007 | Kenmore 62622 Microwave Oven
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
136 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
