Question about NEC LT20 Multimedia Projector
Security code for Nec lt260 multimedia projector
I believe the instruction you give me last time is to delete menu or logo password.That not exactly what im looking for.Security and password is diff in this projector.My problem is the security code at the beginning when we open the projector.
  • NEC Master
  • 19,396 Answers
The menu and logo password are the only ones you can reset by yourself, if you lose your master password you must contact NEC to get the release code.
See page 113 on the manual :
NOTE: Do not forget your keyword. However, if you forget your keyword, NEC or your dealer will provide you with your Release Code.
After you call NEC and get the code do the following:
1. Press and hold the POWER button for a minimum of two seconds.
The projector will be turned on and display a message to the effect that
the projector is security-protected.
2. Select [Projector Options] → [Security] from the menu and press hte ENTER
button.
The Release Code input screen will be displayed as well as your Request
Code (24 alphanumeric characters).
3. Enter your Release Code in the Release Code Input screen.
The projector will turn on.
* If the projector is turned on by entering the Release Code, your Security
will be disabled.
find contact page from here or call the retailer:
NEC Global
Here is also the remote
Posted on Sep 10, 2008
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: security code for Nec lt260 multimedia projector
button.
will be disabled.
NEC Global
I have a NEC LT380 Projector and the Logo Password is locked and I've forgotten the password. How can I reset the password?
This is a theft prevention measure. I quote here from the NEC write up of the projector - "By using passwords, the projector cannot be used by unauthorized persons. Once the security function is in effect, a message requesting the password is displayed when the power of the main unit is turned on. It is impossible to project an image unless the proper password is entered."
As long as you are the legit owner NEC or the dealer you bought it from can give you a release key.
You will need to contact them and provide this proof of purchase. You can reach their support page here: http://www.necdisplay.com/contact-support
Jul 05, 2011 | NEC LT380 LCD Projector
Vertical hazy lines are all that can be seen on my LT260 (nec)
make sure the lcd cables are secure in the main board. if that doesn't fix it the polarizers may be burnt.
May 11, 2010 | InFocus Proxima DP6155 Multimedia...
button.
will be disabled.
NEC Global
Sep 10, 2008 | NEC LT 260K Multimedia Projector
Security code for nec lt 260
The procedure is the same for LT220, LT240 and LT260.
Here is the user manual
LT260/LT240/LT220 User’s Manual
Sep 09, 2008 | NEC LT 260K Multimedia Projector
Security code
From user manual :
"In case you forget your passcode, follow the steps below to delete it.
1. Select the Advanced menu from the Basic/Custom menu. The Passcode
entry screen will be displayed.
2. Press the SELECT (up) button four times and then press the ENTER
button.
The "Warning Passcode!!" message will be displayed.
3. Press the SELECT (down) button four times and then press the ENTER
button.
4. Press the SELECT (right) button four times and then press the ENTER
button.
The "Delete Passcode / Are you sure?" message will be displayed.
Use the SELECT or button to select "Yes" and press the ENTER
button. Your passcode has been deleted."
Sep 08, 2008 | NEC LT20 Multimedia Projector
Security code
You have to contact the manufacturer for a code to reset the password I believe.
Sep 06, 2008 | NEC LT 260K Multimedia Projector
Lt260 projecto
From user manual :
button.
button.
button.
Aug 05, 2008 | NEC LT 260K Multimedia Projector
Nec lt260
Clean optocoupler under pcb 4554B on color disc wheel.
Dusty on this part make not good sincronice with dlp panel.Good luck.
Jun 28, 2008 | NEC LT 260K Multimedia Projector
NEC LT260 PROJECTOR NOISE
To open this projector, you need to undo six screws at the underside of the case. That means you have to turn the projector upsidedown.
Pls note that one of these scews is a little hidden under the carrying handle.
After removing the screws, return the projector to it's normal 'up-side' up, standing position.
Remove the bulb cover srews and remove the bulb cover.
Lift up the top cover carefully starting from the front then all together.
The cooling fan is mounted very near the bulb assembly.
Carefully check the fan blades for any obtacles, wires or even a broken fan blade, that could be causing the noise.
Baba Anji.
Dec 18, 2007 | NEC LT 260K Multimedia Projector
NEC LT20 Multimedia Projector Logo
581 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
