Question about Refrigerators
Water is leaking into the base of the freezer causing ice.
  • fixmyfreezer Sep 10, 2008
    Leaking is located to the right side, I can see some small holes (4 or 5) where I think the water is leaking.
    My Model is MBR1956KES
Hi, katrina, I just called Maytag service las weekend, my city is always dry, but these days there's a lot of rain and humidity is everywhere. The technical guy went to my house and told me that behaviour is "normal" due to the rains and humidity. I know this not a solution, but it seems to be a reasonable answer.
Posted on Sep 15, 2008
    President:
  • 1,462 Answers
I assume a frost-free type.
take back panel off inside freezer and you will see a drain tray at the bottom with a drain hole in the middle. this is blocked usually with ice. melt ice away with a hairdryer and follow up with hot water till water flows away freely
Posted on Sep 10, 2008
Freezer door is rusted at base of the water and ice dispenser. What causes this?
Rust is cause by presence of water
you either have condensation (due to we insulation) or some kind of water leak.
Jul 21, 2014 | Hotpoint HSS25GFP Side by Side...
Water leaking into bottom of refrigerator section
Make sure you dry everything in the freezer when you have the door open and remove ice. It won't be a leak it will simply be the warm air inside the freezer that has turned into condensation. Double check the seal around the door to see if it curled up as that could be letting warm in and cold out giving same results.
Mar 02, 2012 | GE Profile PFSS6PKX Bottom Freezer French...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
Water leak in freezer, build up of ice at the base
Remove the ice maker and fill it with water to see if it is leaking. Or check the pipe that fills the ice maker to see if it leaks or is not positioned correctly. Let me know what you find, Thanks, Sea Breeze
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE top freezer refrigerator automatic ice cube maker leaks water into the freezer, and eventually on the floor. Water seems to be coming from the area that fill up to make more ice cubes.
If it is leaking water in the freezer it will more than likely freeze amongst the ice cubes causing a block of ice.
It is more than likely leaking at the rear of the unit, near the valve or fill tube for the ice, this will run up the rear wall of the unit.
Mar 12, 2009 | GE Freezers
Roper Refrigerator, top freezer leaking water into refrigerator
This is usually caused by a plugged freezer drain. The back wall (or floor) of the freezer may come out to access the drain. Clear out anything visible and run a stiff wire thru it. Test with a cup of water. Hope this helps!
Dec 31, 2008 | Refrigerators
Hi I reckon you gave either an ice block in the defrost drain system or a blockage caused by loose food bits. You can clear the ice block if you keep the fridge off for 24 hours leaving both doors open. If you have a small table fan to circulate warm room air you could speed up the process.
The second type of block with food bits may need you to open the internal rear panel of the fridge and push through a stiff wire to clear the blockage.
Jul 15, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking Water
rakenrol...asteeeeg !!
Feb 19, 2008 | Freezers
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
